It is currently Mon Jul 28, 2025 1:16 am
 Post subject: Diff Ratio
PostPosted: Fri Apr 27, 2007 1:37 pm
How do you externally identify the diff ratio?
PostPosted: Fri Apr 27, 2007 1:46 pm
Jack one wheel up, put it in 4th gear & turn the engine over by hand, counting the number of turns to get exactly 1 wheel revolution.
Mark the start points on the wheel & crank pulley first, then you can pro-rata by measuring the the arc length / circumference of the pulley.
Clear as mud?
PostPosted: Fri Apr 27, 2007 1:48 pm
no wuckers - all makey cents
no part number method.
PostPosted: Fri Apr 27, 2007 1:56 pm
The diff ratio is marked on the side of the crown wheel on the bolt head/bearing side with the number of teeth on the crown wheel and the matching pinion. e.g. Cooper S ratio is 18/62 to give 3.44:1.
Don't think you can see it while it's in the car though :?
Big wheeled Moke ratio should be 4.1 or 4.2:1, but a Morris 1100 unit would be a good swap with their 4.3:1 ratio
Failing that, may be run 10" mags?
PostPosted: Fri Apr 27, 2007 5:01 pm
I swopped the 4.267 in my 1275 Californian with a 3.765 and now wish I'd used a 3.444 - plenty of grunt allows easy cruizin' without it screaming it's tits off.
Probably not much chop tho' if your'e into sand dunes or stump pulling.............. :roll:
PostPosted: Fri Apr 27, 2007 5:09 pm
Bloke is running the big 998 - screaming is what it does best!
that and the fact it wouldn't be able to hold onto 4th into a slight breeze with a 3.44 diff :P
PostPosted: Fri Apr 27, 2007 5:15 pm
Looks like 98 km.h is all she will do :cry: - maybe I should get it registered before I try again :P
PostPosted: Fri Apr 27, 2007 5:23 pm
i thought it was on the side of the diff casing
