Diff Ratio https://www.ausmini.com/forums/viewtopic.php?f=2&t=31172 |
Author: | Blokeinamoke [ Fri Apr 27, 2007 1:37 pm ] |
Post subject: | Diff Ratio |
How do you externally identify the diff ratio? |
Author: | awdmoke [ Fri Apr 27, 2007 1:46 pm ] |
Jack one wheel up, put it in 4th gear & turn the engine over by hand, counting the number of turns to get exactly 1 wheel revolution. Mark the start points on the wheel & crank pulley first, then you can pro-rata by measuring the the arc length / circumference of the pulley. Clear as mud? |
Author: | Blokeinamoke [ Fri Apr 27, 2007 1:48 pm ] |
no wuckers - all makey cents no part number method. |
Author: | awdmoke [ Fri Apr 27, 2007 1:56 pm ] |
The diff ratio is marked on the side of the crown wheel on the bolt head/bearing side with the number of teeth on the crown wheel and the matching pinion. e.g. Cooper S ratio is 18/62 to give 3.44:1. Don't think you can see it while it's in the car though ![]() Big wheeled Moke ratio should be 4.1 or 4.2:1, but a Morris 1100 unit would be a good swap with their 4.3:1 ratio Failing that, may be run 10" mags? |
Author: | AEG163job [ Fri Apr 27, 2007 5:01 pm ] |
I swopped the 4.267 in my 1275 Californian with a 3.765 and now wish I'd used a 3.444 - plenty of grunt allows easy cruizin' without it screaming it's tits off. Probably not much chop tho' if your'e into sand dunes or stump pulling.............. ![]() |
Author: | awdmoke [ Fri Apr 27, 2007 5:09 pm ] |
Bloke is running the big 998 - screaming is what it does best! that and the fact it wouldn't be able to hold onto 4th into a slight breeze with a 3.44 diff ![]() |
Author: | Blokeinamoke [ Fri Apr 27, 2007 5:15 pm ] |
awdmoke wrote: Bloke is running the big 998 - screaming is what it does best!
that and the fact it wouldn't be able to hold onto 4th into a slight breeze with a 3.44 diff ![]() Looks like 98 km.h is all she will do ![]() ![]() |
Author: | Spaceboy [ Fri Apr 27, 2007 5:23 pm ] |
i thought it was on the side of the diff casing |
