It is currently Sun Jul 27, 2025 2:58 pm
PostPosted: Sat Apr 28, 2007 6:21 pm
Hi Everyone,
Just rebulding my LS1275 and have run into a couple of small issues and i need some help.
1. Subframe has taken a massive hit to the front LH side, i have a subframe from a 74 clubman, it appears to be the same and i was going to swap all the parts onto it. Questions. Are they the same?
2. Bolt hole in 1 caliper has been enlarged to take a larger bolt and is very sloppy, Is the outer axle stub axle bearing holder that the caliper bolts too the same drum brake set up.
Also would anyone have a LH caliper that they would like to sell?
Thanks everyone for your future help.
Ryan
Ryan
LS1275 - Hi Ho Silver
Moke 1981 - Mokee
Moke 1981 - Project
Moke 1978 - The Yellow One
PostPosted: Sat Apr 28, 2007 6:32 pm
Subframes would be the same, unless a hydro subframe (which is unlikely in a 74??).
Drum brake hubs are different to disc hubs, if that's what you are talking about.
PostPosted: Sat Apr 28, 2007 6:35 pm
Hi mate,
Not talking about the hub, talking about the bearing carrier/ upright between the upper and lower control arm. Easiest way to explain the but the caliper bolts to
If it makes not sense i will talke a photo
Ryan
Ryan
Moke 1981 - Mokee
Moke 1981 - Project
PostPosted: Sat Apr 28, 2007 6:54 pm
Ryan Paterson wrote:
Hi mate,
Ryan
Just to confuse you...
That part the caliper bolts to is an upright on some cars, but in a Mini it's called a swivel hub.
The outer round bit that the wheel bolts onto is called a hub in some cars, but in a Mini it's called a drive flange... :wink:
No a disc one is NOT the same as a drum one, the drum swivel hub has no mounting lugs for the caliper to bolt to.
PostPosted: Sat Apr 28, 2007 7:07 pm
In order
1. The sub frames are the same. You often find that when a bang has happened that you can drop the old out but buggered if oy can get a newer one in because of deformation
2. A die grinder will do the job
PostPosted: Sat Apr 28, 2007 11:52 pm
When you say enlarged to take a bigger bolt I think of one thing to do with brakes. The steering arm to brake assembly has two bolts. They have sleeves that they go in, if you don't have a sleeve on one it would appear to be a hole too big for your bolt I think. I'm thinking a fair way back to when I put the discs on my car 2 years ago though.
PostPosted: Tue May 01, 2007 11:01 am
Hi Guys,
Thanks for the help. I will get some pics and post them soon. unfortunatly the car is in Vic and i am, in NSW so it is not so easy. Will reoport back soon. Good news is i have a Caliper to replace the stuffed one.
Regars
Ryan
Ryan
Moke 1981 - Mokee
Moke 1981 - Project
