It is currently Sun Jul 27, 2025 9:06 pm
 Post subject: thermostat housing
PostPosted: Fri Apr 27, 2007 10:24 pm
does a thermostat housing of an 850 fit a 1275 ?
PostPosted: Fri Apr 27, 2007 10:28 pm
I would think not.
PostPosted: Fri Apr 27, 2007 10:29 pm
If car is a roundnose or early Clubby it will fit, the bolt pattern and pipe angle is the same. But original 850 one was shorter on top, make sure the thermostat fits in (but I think it will).
On late Clubby radiator with top hose going back to near radiator neck, no, it won't.
Easiest solution then is get another radiator. :wink:
Last edited by drmini in aust on Fri Apr 27, 2007 10:30 pm, edited 1 time in total.
PostPosted: Fri Apr 27, 2007 10:30 pm
no its a front facing housing
PostPosted: Fri Apr 27, 2007 10:33 pm
OK then.
