Clubman gauges - printed circuit?!? https://www.ausmini.com/forums/viewtopic.php?f=2&t=3119 |
Page 1 of 2 |
Author: | J_A_M [ Sun Nov 28, 2004 8:25 pm ] |
Post subject: | Clubman gauges - printed circuit?!? |
If the printed circuit on the back of a set of Clubman S gauges is broken.....what happens? I have 2 sets with the circuit split where it joins the tacho.... ![]() ![]() |
Author: | poeee [ Sun Nov 28, 2004 8:26 pm ] |
Go buy another one? Put Rover guages in ![]() |
Author: | danidad [ Sun Nov 28, 2004 8:35 pm ] |
im an electronics technician by trade... and circuit boadrs are usually easy to fix believe me ive done hundreds (dropped stereos etc) if the copper track is broken all you do is gently scratch off a section of the usually green coating which insulates the copper track on either side of the break.. (enough to solder a link to) 5mm should be enough.. then get a short piece of wireto cover the distance between the two cleared copper pads put a quick solder on each pad and a quick solder on each end of the wire (hold the wire gently with needle nose pliers and do it quick as the heat will melt the insulation...when its cool solere each end to the respective pads and bingo... the actual board itself can be glued if needs be.. |
Author: | J_A_M [ Sun Nov 28, 2004 8:42 pm ] |
OK, thanks Jeff, I can handle that. What happens if I leave it broken? Will the gauges not work or is it for the dash lightS? |
Author: | drmini in aust [ Sun Nov 28, 2004 8:45 pm ] |
The lights in tacho won't work, nor will the tacho read. The 12V feed comes from the PCB, the trigger wire to coil is a separate circuit. |
Author: | danidad [ Sun Nov 28, 2004 8:48 pm ] |
if the board is broken but the copper track is still intact it will work (for a while but it will break and probably sooner than later.. a bit of glue will save it... with the track brolen it more than likely wont work (unless its just an earth, and it has another) or the pad was purely for mounting purposes... neither of these is likely though.. if you fix it it will be as good as new. |
Author: | danidad [ Sun Nov 28, 2004 8:51 pm ] |
if my clubby had a dash id have a look to see exactly what you mean |
Author: | J_A_M [ Sun Nov 28, 2004 8:51 pm ] |
hmmmm........ A mini project for this week.....fix both sets of gauges. ![]() Thanks guys! |
Author: | J_A_M [ Sun Nov 28, 2004 8:53 pm ] |
danidad wrote: if my clubby had a dash id have a look to see exactly what you mean
Jeff, I think this particular break in the S set of gauges is common. It's a weak link between the tacho and the other 2 gauge pod. The tacho is like an after thought on the side. |
Author: | danidad [ Sun Nov 28, 2004 9:00 pm ] |
hard to say without seeing it but might be a good idea to think about improving the rigidity of the item...can you brace it a bit maybe glue or splint on it is the break mid board, or at the edge where a guage is attached might be another usefull mod for your site if ita a common drama |
Author: | J_A_M [ Sun Nov 28, 2004 9:06 pm ] |
good thinking 99..... I'll work something out and document it, because I think it's a common problem. |
Author: | nermil [ Sun Nov 28, 2004 9:53 pm ] |
J_A_M wrote: good thinking 99..... I'll work something out and document it, because I think it's a common problem.
it sure is. the elderly auto-electrician dude here in the valley worked some magic with mine. said it won't bother me for another 20 years if im careful! ![]() |
Author: | J_A_M [ Mon Nov 29, 2004 7:44 am ] |
so what did he do Darren...??? |
Author: | aaron [ Mon Nov 29, 2004 8:38 am ] |
One thing to be very aware of anton is that being a very fine plastic PCB ( it is about as thick as a couple of sheets of paper dani dad, not actually a board) Hence you will need to use a very low heat soldering iron as you can easily burn and melt it. I had and now have again one in my clubman. Mine was originally broken and i soldered it with a low heat iron and all was fine. Danidads idea with using a thin wire between would go good as as when the PCB bends it doesn't break the join. It'll last quite a while if not forever. Just comes down to how often you pull the dash out. By the way, i am sure most of you guys already know but the PCB's from the UK are different and you can use them with aussie guages. Cheers Aaron |
Author: | min13k [ Mon Nov 29, 2004 8:15 pm ] |
anton if ya want i have repaired more than i care to remember i can do it for you makka |
