It is currently Sat Jul 19, 2025 11:19 pm
 Post subject: shocks on hydro
PostPosted: Sat Apr 28, 2007 2:04 pm
will i get any real benifit out of putting front shockers on a hydro i get the feeling i wont have much improvement in handling or cornering
Enjoy Chris ;)
PostPosted: Sat Apr 28, 2007 2:30 pm
It will help the fore and aft pitching, won't affect cornering much.
But putting comp bumpstops on rear will reduce understeer and improve turn-in. :wink:
PostPosted: Sat Apr 28, 2007 2:32 pm
how does comp bump stops differ from a normal bump stop? thanks for your help to
Enjoy Chris ;)
PostPosted: Sat Apr 28, 2007 4:48 pm
Comp bumpstops add to the `spring rate' at rear, they are aeon springs.
The suspension sits on these type of bumpstop at all times, not just when you hit a bump.
See
http://www.minimania.com/web/Item/C%2DA ... Detail.cfm
Available from Karcraft, Minisport etc out here.
PostPosted: Sat Apr 28, 2007 4:54 pm
Also having competition bump stops means you can probably get home if a hydro bag blows, as it won't sit the car's arches on the tyres. Still gotta go slow though.
I have always done the shocky mod, great improvement and little dollars too. One pair of upper mounts off an old derelict clubman and a cheap pair of shocks (maybe even the oness of the clubby if still good). If the shocks are too stiff, you will shatter your teeth as they will add to the damping already present in the hydro system.
PostPosted: Sat Apr 28, 2007 5:59 pm
Hydro bags have internal damping valves but they will deterioate after all this time.
Adding any shocks to the front will improve the damping back to new.
Adding good shocks will make it better than new. :wink:
PostPosted: Sat Apr 28, 2007 8:26 pm
do the shockie thing to the front and add a rear sway bar for fab results on hydro
PostPosted: Sun Apr 29, 2007 10:59 am
thanks for all ya help i think ill do these conversions for the price and effort should be relatively easy install cheers
Enjoy Chris ;)
Users browsing this forum: Astroblue, Majestic-12 [Bot] and 85 guests
