It is currently Fri Jul 18, 2025 9:05 pm
 Post subject: Doc's correct
PostPosted: Mon Nov 29, 2004 10:07 am
Doc came over yesturday arvo after a cry for help Morris would not start. I checked all the normals and doc did the thumb presure test..three and four ver little pressure, head gasket gone.. :cry:
Just taken the head off and you can guess it.. both 3 and 4 piston are wet and a nice piece of gasket is missing.
Look like Sue's without Morris for a little bit again :? she's not happy
PostPosted: Mon Nov 29, 2004 10:40 am
well pull your finger out then Jim....nothing worse than a wife who is unhappy.....
PostPosted: Mon Nov 29, 2004 10:44 am
I have...Doc and I just need to do some work on the head to correct it..It may not be flat ? and I know what you mean about the wife..not forgetting Sue's a redhead :cry:
PostPosted: Mon Nov 29, 2004 10:46 am
gafmo wrote:
.....not forgetting Sue's a redhead :cry:
PostPosted: Mon Nov 29, 2004 11:12 am
Never you just have to know how to play them but i'm always learning :lol:
PostPosted: Mon Nov 29, 2004 11:28 am
us married blokes never stop learning...that's my theory on marraige....because women are never wrong...apparently :wink:
PostPosted: Mon Nov 29, 2004 11:30 am
Thats what they all tell me....are they correct :?:
PostPosted: Mon Nov 29, 2004 11:31 am
This time, we'll use a different gasket- NOT a copper one. They don't make them like they used to. :cry:
PostPosted: Mon Nov 29, 2004 11:36 am
I'm still going to need an manifold and heater tap gaskets which I'll get a few other things sent to me at the same time.. :lol:
PostPosted: Mon Nov 29, 2004 1:07 pm
Get a metal ruler out and check if it's flat.
PostPosted: Mon Nov 29, 2004 1:43 pm
:shock: Get it fixed, gaf!
PostPosted: Mon Nov 29, 2004 4:03 pm
Doc and I had some fun with the Doc's new Mill :D
I'll put a picture up of the gasket in a sec
PostPosted: Mon Nov 29, 2004 4:13 pm
number 3 and 4 has a good size gap
1 and 2 is a little bit harder to see but it was going also
Worked out what the problem was...Haynes book of lies say to do them up 40...I should have done them 50 leason learnt
PostPosted: Mon Nov 29, 2004 4:53 pm
go a metro turbo gasket. shouldn't have the problem then
PostPosted: Mon Nov 29, 2004 5:23 pm
Its an 1100 not a 1275
