Ryan Paterson wrote:
Hi mate,
Not talking about the hub, talking about the bearing carrier/ upright between the upper and lower control arm. Easiest way to explain the but the caliper bolts to
If it makes not sense i will talke a photo
Ryan
Just to confuse you...
That part the caliper bolts to is an upright on some cars, but in a Mini it's called a swivel hub.
The outer round bit that the wheel bolts onto is called a hub in some cars, but in a Mini it's called a drive flange...
No a disc one is NOT the same as a drum one, the drum swivel hub has no mounting lugs for the caliper to bolt to.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
