Back Tyre Scraping https://www.ausmini.com/forums/viewtopic.php?f=2&t=31262 |
Page 1 of 2 |
Author: | thedog74 [ Mon Apr 30, 2007 11:33 am ] |
Post subject: | Back Tyre Scraping |
Got a bit of a problem recently when 3 of my mates and I decided to do a road trip in the clubbie. To cut a long story short, we had to ditch one of them because my left hand rear tyre wore a nice groove in it everytime we went over a pebble. I now have a nice 1/2cm groove in back left hand tyre. Is there any way of doing anything with the suspension to alter the height or should I just tell my mates to lose weight. |
Author: | thedog74 [ Mon Apr 30, 2007 11:59 am ] |
Ok, where from?? |
Author: | thedog74 [ Mon Apr 30, 2007 12:15 pm ] |
Umm, ok I thought they were specialised. So I go to bunnings and ask them for shims right?? ![]() I'll give it a go tonight. Thanks for your help |
Author: | Hanra [ Mon Apr 30, 2007 12:19 pm ] |
Provided u have dry suspension... U may need to experiment with thickness's. What profile tyres do you have on the rear? Do they have enough air in them? Washers come in a lot of different diameters, so you will need to know wat size the inside diameter must be... I couldnt tell you off the top of my head. |
Author: | thedog74 [ Mon Apr 30, 2007 12:28 pm ] |
actually im pretty sure its hydro. Cant remember on the tyres, I've got 12" rims and whatevers standard. Got them from Tempe tyres. |
Author: | drmini in aust [ Mon Apr 30, 2007 12:29 pm ] |
A 72 clubby would be hydro unless someone has converted it. If hydro, either it needs pumping up or the rear bumpstops have had it. If replacing rear bumpstops, I recommend fitting the competition hydro kit. ![]() |
Author: | Hanra [ Mon Apr 30, 2007 12:37 pm ] |
There ya go its hydro, so you can simply forget anything that i have posted here!!!!! |
Author: | thedog74 [ Mon Apr 30, 2007 1:47 pm ] |
any idea of where to get hydro's pumped up? |
Author: | drmini in aust [ Mon Apr 30, 2007 2:49 pm ] |
Ummm, it would help if we knew where ya is at... ![]() I can do it in Sydney west, but there are lots of people around with pumps. Or, make your own... ![]() |
Author: | Ziegech [ Mon Apr 30, 2007 5:00 pm ] |
i rotated my front and back tyres and never carried 5 people again. it slowly loses the cut as the tyre wears down |
Author: | Hanra [ Mon Apr 30, 2007 5:36 pm ] |
I thought Minis only have the seating capacity for 4 persons? |
Author: | 1360 LS [ Mon Apr 30, 2007 5:40 pm ] |
Hanra wrote: I thought Minis only have the seating capacity for 4 persons?
I have sealbelst for 5 so legally i bleieve if theres a seatbelt you're allowed to use them. |
Author: | 1018cc [ Mon Apr 30, 2007 5:51 pm ] |
1360 LS wrote: Hanra wrote: I thought Minis only have the seating capacity for 4 persons? I have sealbelst for 5 so legally i bleieve if theres a seatbelt you're allowed to use them. I still thought that you still had to have it registered for 5 people even though you may have 5 seat belts. |
