d4r83 Side entry cap
https://www.ausmini.com/forums/viewtopic.php?f=2&t=31272
Author:  Sprite_Man [ Mon Apr 30, 2007 3:02 pm ]
Post subject:  d4r83 Side entry cap
Help someone please :?
Is there a side entry cap for a d4R83 dizzy ?
thanks crew
Author:  drmini in aust [ Mon Apr 30, 2007 3:06 pm ]
Never seen one, I think the best you can do is use 90* ends on the leads. :wink:
If it's in a Mini, putting 10mm spacers behind the grille gives you a little more room too.
Author:  Sprite_Man [ Mon Apr 30, 2007 3:08 pm ]
Thanks Doc. :D
I hadn't seen one either, but often I am wrong :oops: and was after a second opinion.
Thanks
Author:  Lillee [ Mon Apr 30, 2007 3:26 pm ]
Narp never found one. If you do let me know where :wink:
Author:  gafmo [ Mon Apr 30, 2007 10:02 pm ]
I use Both the 90* angle end on a Lead and also 10 mil spacer on the Grill. I use Grill Buttons and it makes it much easier to get a Grill on and off in seconds
Author:  Mike [ Tue May 01, 2007 3:07 am ]
Same here, but w/o the spacers - dont feel I need them with the grille buttons. i find the grille buttons kinda ugly but awsomely useful.
Author:  Convertible Mini [ Tue May 01, 2007 5:57 am ]
Post subject:  Side entry Hitachi Distributor caps.
I have been researching this for the last 12 months. No one in any Bosch, Champion or Repco warehouse is helpful in this matter. All the Ignition parts Book that I have do not specify what cap fits what distributor and it is difficult judjing form the pictures in the book if one will fit. But do not dispair I might have the answer soon I am trying overseas and will be getting Bulk if I find the correct part. I have been asked for this part many times before.
Author:  Sprite_Man [ Tue May 01, 2007 8:39 am ]
Just came across this site. http://www.mcs.vuw.ac.nz/~kris/escort/ignition.shtml
I have the Pulsar dizzy :) , but never seen the one out of a Honda :shock: . Does that have a shoter shaft, or perhaps a smaller cap ? Anyone? Sorry I don't know the part number.
Author:  supercharged 850 [ Tue May 01, 2007 10:52 am ]
Ive shaved about 5mm off the dizzy cap posts, as well as trimming a bit off the rubber sleeves ---- gives it a bit more room.
Author:  gafmo [ Tue May 01, 2007 7:58 pm ]
to much effort for me...plus I already had the Buttons :wink:
