It is currently Tue Jul 29, 2025 1:09 am
 Post subject: air conditioning
PostPosted: Mon Apr 30, 2007 3:32 pm
hi all
i'm going to put a a/c system in my mini. it's one of those ones that bolts under the dash.
and because most of us are drivers this may be a tricky one, but does it get in the way of the passengers legs??
yes, searched the forum, but no one has said anything about losing leg space.....i can see the puns about someone losing their legs or there being heaps of space due to being a midget/dwarf/vertically challenged/dog/tortoise...etc
PostPosted: Mon Apr 30, 2007 6:18 pm
Slow-Po
I've got the underdash system, and there is no problem with leg space being lost as it sits above the passenger's upper shin / lower knee area. If you are 6ft+ then it might be a problem, but then again the whole rest of car might also be a bit tight. :)
PostPosted: Mon Apr 30, 2007 8:21 pm
Where do you get those ac systems from is the complete system inside the car.meaning no pump/condensor/pipe work in engine bay
PostPosted: Mon Apr 30, 2007 8:47 pm
PostPosted: Mon Apr 30, 2007 8:53 pm
Or....
PostPosted: Tue May 01, 2007 6:14 am
Ah morris im very keen on buying an ac unit like the one in the bottom pic used in the big yank tank would fit nice into a mini :lol: :lol: :lol:
PostPosted: Tue May 01, 2007 9:14 am
haaaaaaaaaaa seppos... don't you love when Firth goes to the USA on the chaser
PostPosted: Tue May 01, 2007 1:33 pm
im interested in getting one of the underdash units too. anyone know where to get them from?
PostPosted: Tue May 01, 2007 2:09 pm
brickworx. do google search
PostPosted: Tue May 01, 2007 8:31 pm
I particularly like the genset sitting on the trunk (boot). :lol: 8)
PostPosted: Tue May 01, 2007 8:35 pm
You don't expect him to have to run a power cord do you? :roll: :lol: :lol: :lol:
It is a good bit of creative engineering. I love the way that he has sealed the window hole with expanding foam. :wink:
PostPosted: Tue May 01, 2007 10:35 pm
No probs with leg room as noted, but my vents are there too so the passenger gets blasted with cold air (knee high, ok for betty swollocks :wink: ). I recon if your going to retro fit one get the one with the vents in the dash.
PostPosted: Tue May 01, 2007 10:42 pm
Slow-Po
You can have both, the underdash A/C with the dash that has vents higher up.
Just need to find the right dash. 8)
