It is currently Thu Jul 24, 2025 1:13 pm
 Post subject: simple gearbox question
PostPosted: Mon Apr 30, 2007 10:12 pm
good evening
Are the drive gears in the box(not dog gears on the syncro) straight cut or helical(sp?)
Thanks ya'll
blokeinamoke wrote:
PostPosted: Mon Apr 30, 2007 10:21 pm
depends if you count reverse! or if someone has installed a s/c gearset. :roll:
standard all gears are helical cut, except reverse on all gearboxes. remember 4th gear is simply the input shaft locked to the output shaft for 1:1 ratio.
drop gears are helical cut standard.
michael
PostPosted: Mon Apr 30, 2007 10:29 pm
1st gear is straight cut too.
