simple gearbox question https://www.ausmini.com/forums/viewtopic.php?f=2&t=31289 |
Author: | mini-dunger [ Mon Apr 30, 2007 10:12 pm ] |
Post subject: | simple gearbox question |
good evening Are the drive gears in the box(not dog gears on the syncro) straight cut or helical(sp?) Thanks ya'll |
Author: | mickmini [ Mon Apr 30, 2007 10:21 pm ] |
depends if you count reverse! or if someone has installed a s/c gearset. ![]() standard all gears are helical cut, except reverse on all gearboxes. remember 4th gear is simply the input shaft locked to the output shaft for 1:1 ratio. drop gears are helical cut standard. cheers michael |
Author: | slinkey inc [ Mon Apr 30, 2007 10:29 pm ] |
1st gear is straight cut too. |
