It is currently Wed Jul 30, 2025 1:45 pm
 Post subject: carburetor oil
PostPosted: Tue May 01, 2007 9:05 am
Hi, i need some more oil for my SU carburetor and i dont know what to use. I went to auto pro and they say that air tool oil is ok... or what other oil should i use?
Thanks
PostPosted: Tue May 01, 2007 9:51 am
You can buy genuine SU oil, (mini or carb specialists)
You can use ATF
You can use any monograde oil. 10 to 20W is best. People may say that engine oil is OK, but it really isn't in 99% of cases.
Sewing machine oil , or 3 in 1 oil are also used by some.
I use a mtorcycle fork oil monograde 10W.
Seems to do a very nice job.
 Post subject: Re: carburetor oil
PostPosted: Tue May 01, 2007 10:13 am
Leyland Mini owners instruction manual wrote:
Failure to keep the piston damper oil level correct may cause the piston to flutter and reduce acceleration.
Engine oil SAE20 (alternative 20/50) should be used to top up the level to 12.70mm (1/2 in) above the top of the hollow piston rod.
Never use a heavy bodied lubricant
PostPosted: Tue May 01, 2007 6:36 pm
Yes it does say 20W 50 in all workshop manual I got, but that's silly. I followed it first off and it reduces acceleration to near nothing piston won't lift up. Not even worth trying IMO.
ATF (auto trans fluid) is the most commonly used dashpot and is a good midrange for winter and summer temperatures, for a normal car I'd use it and I do, but for me it's a little thin, I'm going to change to thicker stuff or thicken the ATF a bit (by mixing thicker oil with it) as my piston lifts up a bit too quickly (my car is supercharged hence this is an issue). From what I've read a bit too thick is less noticeble to to thin.
PostPosted: Tue May 01, 2007 7:53 pm
I also you Auto Transmition Oil...but would like to try a little Thinner...any idea's to thin it a little :idea:
PostPosted: Tue May 01, 2007 7:57 pm
I use baby oil ..no I really do :D
PostPosted: Tue May 01, 2007 8:05 pm
Your a Slippery little Sucker arn't you :wink:
PostPosted: Tue May 01, 2007 8:13 pm
in the carb you dope only because I couldnt get ky into it :P
PostPosted: Tue May 01, 2007 8:27 pm
2 stroke outboard oil is thinner than ATF. :wink:
PostPosted: Tue May 01, 2007 8:39 pm
Air is even thinner. 8)
That is what was recomended for the 175CD Strombergs on the XU1. :? (I used atf in mine)
PostPosted: Tue May 01, 2007 8:40 pm
Barney's twin HS4s run air in summer and ATF in winter. 8)
PostPosted: Tue May 01, 2007 8:45 pm
A mate that was racing an XU1 thought that air was too thick so he tried it with the dampers removed and just blank caps.
Didn't work! :lol: He went back to running dampers and air. :wink:
PostPosted: Tue May 01, 2007 9:02 pm
Havent got any of that...what 2 stroke Lawn Mower then :?
PostPosted: Tue May 01, 2007 9:12 pm
Jimbo I offered you some the other day... :wink:
PostPosted: Tue May 01, 2007 9:27 pm
May have to pop over during this week or try some of Blokes baby oil :shock:
Users browsing this forum: fuzzy-hair-man and 100 guests
