are mk 1 and mk2 doors interchangable https://www.ausmini.com/forums/viewtopic.php?f=2&t=31357 |
Page 1 of 2 |
Author: | dougys [ Thu May 03, 2007 8:13 am ] |
Post subject: | are mk 1 and mk2 doors interchangable |
are mk 1 and mk2 doors interchangable cos i have sliding windows but would like to change them to windups. ![]() |
Author: | ryan [ Thu May 03, 2007 8:23 am ] |
yes they are! Mk1 doors are gettng rare and are worth a bit now, so hold onto them, or sell them for what they are worth. Ryan |
Author: | cush [ Thu May 03, 2007 8:23 am ] |
absolutely.. though, i'm not sure australia really has the "Mark" designationof generations of cars... the answer is still yes tho... any external hinge door will fit... but good luck finding a place to put all that money you get from selling the sliders.. ![]() |
Author: | dougys [ Thu May 03, 2007 8:32 am ] |
Post subject: | doors |
how much are mark 1 doors worth cos mine are in ex condition. |
Author: | cush [ Thu May 03, 2007 8:34 am ] |
they're worth what ever someone is willing to pay... bearing in mind, that it's not only nice, but healthy for the mini scene to keep parts prices under control... ![]() |
Author: | Harley [ Thu May 03, 2007 8:39 am ] |
cush wrote: absolutely..... any external hinge door will fit...
I think it should be pointed out clubby doors won't fit, as they have a different catch system. You'll need sixties (turn handle) doors. ![]() |
Author: | dougys [ Thu May 03, 2007 8:42 am ] |
i wont be selling them. I was just curious. i will put them on my mk2 project car. and put the wind ups on the mk1street car project im doing |
Author: | cush [ Thu May 03, 2007 8:44 am ] |
Harley wrote: cush wrote: absolutely..... any external hinge door will fit... I think it should be pointed out clubby doors won't fit, as they have a different catch system. You'll need sixties (turn handle) doors. ![]() so the doors should, but need a different catch/handle? |
Author: | PetenSoaf [ Thu May 03, 2007 8:50 am ] |
cush wrote: Harley wrote: cush wrote: absolutely..... any external hinge door will fit... I think it should be pointed out clubby doors won't fit, as they have a different catch system. You'll need sixties (turn handle) doors. ![]() so the doors should, but need a different catch/handle? And a different B-pillar. . . |
Author: | dougys [ Thu May 03, 2007 8:54 am ] |
Thanks for your help guys Cheers Carl |
Author: | cush [ Thu May 03, 2007 8:57 am ] |
PetenSoaf wrote: cush wrote: Harley wrote: cush wrote: absolutely..... any external hinge door will fit... I think it should be pointed out clubby doors won't fit, as they have a different catch system. You'll need sixties (turn handle) doors. ![]() so the doors should, but need a different catch/handle? And a different B-pillar. . . right.. minor detail... ![]() |
Author: | Mike_Byron [ Thu May 03, 2007 9:12 am ] |
Cushy I notice your on zero plus 5 - do let us know when things happen Now doors - the clubbie (and some late roundie doors) had an anti- burst door catches to comply with then current ADR (or what ever they were called then). Its best to just say that clubbie doors are not compatible. |
Author: | graham in aus [ Thu May 03, 2007 9:32 am ] |
Mike; it happened! See general discussion! ![]() http://www.ausmini.com/forums/viewtopic.php?t=31211 |
Author: | Mokesta [ Thu May 03, 2007 9:36 am ] |
The B pillars are not the same for sliding window doors and roundy wind-up doors. The doors fit but the seals will be a bit off and the strikers will be a bit off too. The differences include: The strikers have a different screw pattern The strikers are set into the B pillar more for wind-up doors (sliders may pop open is these aren't packed on a later shell) The white plastic doover that alignes the door and aperture is swapped on the door/b-pillar in the two set-ups. The seam that the door seal attaches to on the B pillar below the striker (shin height) is in a different place on the two shells. One model has a vertical straight seam, the other is different and has another bit of angle or similar there (sorry to be vague, only looked closely once) So, the doors are compatible, but it isn't a simple unscrew-the-hinges-and-swap exercise. I reckon someone should post pics of the three Australian setups and make it a sticky. This Q comes up every couple of months. M |
Author: | clubmn [ Thu May 03, 2007 5:52 pm ] |
Mokesta wrote: The B pillars are not the same for sliding window doors and roundy wind-up doors. The doors fit but the seals will be a bit off and the strikers will be a bit off too.
The differences include: The strikers have a different screw pattern The strikers are set into the B pillar more for wind-up doors (sliders may pop open is these aren't packed on a later shell) The white plastic doover that alignes the door and aperture is swapped on the door/b-pillar in the two set-ups. The seam that the door seal attaches to on the B pillar below the striker (shin height) is in a different place on the two shells. One model has a vertical straight seam, the other is different and has another bit of angle or similar there (sorry to be vague, only looked closely once) So, the doors are compatible, but it isn't a simple unscrew-the-hinges-and-swap exercise. I reckon someone should post pics of the three Australian setups and make it a sticky. This Q comes up every couple of months. M I like hearing an answer when somebody knows what they are talking about, Why on earth would others post if they have no idea or had no experience's themselves in the subject. oh im not just talking in relation to this post. |
