Making a trailer from rear subframe https://www.ausmini.com/forums/viewtopic.php?f=2&t=31394 |
Page 1 of 2 |
Author: | Flying Brick [ Fri May 04, 2007 1:23 pm ] |
Post subject: | Making a trailer from rear subframe |
Gday, A friend is wanting to make a small trailer and it was suggested to him to use a Mini rear subframe. I have a spare one for him but it is a hydro one. Is it possible to use this as hydro by just running lines to the bags. Has anyone done this and what problems might I face. I could convert it to dry but then I would need to by the bits. Any help much appreciated. Steve. |
Author: | drmini in aust [ Fri May 04, 2007 1:41 pm ] |
I'd say you can use it for a trailer, IF you cap off the hydro lines and use hydro fluid in it still. Forget air, it won't carry any load with only 120psi or so. Hydro runs ar near 300psi. You will still have suspension- the fluid is interposed between the suspension strut and the rubber cone (which a displacer has as part of its construction). |
Author: | Flying Brick [ Fri May 04, 2007 2:01 pm ] |
Thanks doc, I would still use the hydro fluid, I have a pump so thats no worries. It won't be carrying huge weights, just RC planes. Steve. |
Author: | bnicho [ Fri May 04, 2007 2:03 pm ] |
Put 5/16 SAE blanking caps on where the hydro lines used to go to the front bags, so you have two isolated bags. Then pump up the hydro as normal A Mini rear subframe is acutally a lot heaver than a light duty trailer axle with hubs and a couple of leaf springs. Although a Mini subframe based one would probably handle better. ![]() I'm halfway through making a trailer now. The original intention was to use a hydro rear subframe. Instead I'm now using a Suzuki 800 leaf sprung rear axle with the drums redrilled to Mini stud pattern. Saves quite a few kgs - the complete frame on wheels weighs 80kg! |
Author: | VicMini13 [ Fri May 04, 2007 2:22 pm ] |
VMCI has a trailer made on a hydro subframe. It's a heavy as all s**t - heavy steel frame, wooden box and fibreglass lid, but tows like a dream - even behind a Mini - with barbecue and bottle, 2xtables, 12x12 canvas marque+poles+ropes+pegs, enough sticks and flags to run 10 concurrent motorkhanas, and various miscellaneous junk. It is quite long though - from memory a bit longer than a Mini from tow hitch to end. Not a good angle that doesn't realy show its length, but it's the only one I can find at the moment... http://mini.org.au/photos/pitourjohn.jpg |
Author: | mickmini [ Sat May 05, 2007 8:32 am ] |
hydro would work well for a dual axle trailer since the hydro is naturally load sharing on each side if you hook the bags on each side together like on the car it came from..... |
Author: | simon k [ Sat May 05, 2007 10:56 am ] |
I love my little trailer.... it's got a dry subframe under it. I do need to put some dampers under it somehow, as it bounces like crazy. I've thought about swapping the dry subframe for a hydro one. I need to strip it and rebuild it at some stage, but it's really well made - not by me though. Also, a complete dry subframe with shockers and spacered drums weighs 45kg according to my bathroom scales ![]() ![]() |
Author: | Flying Brick [ Sat May 05, 2007 12:41 pm ] |
Thanks guys for the replies, that is a good looking trailer skssgn and the VMCI one. I think I will give it a go with the hydro, by the sounds of it , it should be fine. If not it can be swapped to dry. Steve. |
Author: | simon k [ Sat May 05, 2007 1:11 pm ] |
go for it ![]() the fellow who made my trailer built it so that the subframe bolts in using the standard mounting points. I'll be able to unbolt it and take the bed off very easily, and swap the subframe without changing anything - worth you doing the same luckily for me he left it sit in a paddock for 10 years and I bought it for $50! (not that I've paid him yet ![]() |
Author: | Mike_Byron [ Sat May 05, 2007 3:10 pm ] |
I am in that photo with some bits and pieces that I recognise |
Author: | simon k [ Sat May 05, 2007 6:12 pm ] |
Mike_Byron wrote: I am in that photo with some bits and pieces that I recognise
lol, yes you are Mike - I've still got some of that junk laying about |
Author: | Flying Brick [ Sun May 06, 2007 8:34 pm ] |
Gday again, I was just thinking about the trailer again and I was wondering if it is necessary to put the helper springs on. I am thinking not as the weight of the top part should keep it down, but I am not too sure. Thanks. Steve. |
Author: | bnicho [ Sun May 06, 2007 9:36 pm ] |
Flying Brick wrote: Gday again,
I was just thinking about the trailer again and I was wondering if it is necessary to put the helper springs on. I am thinking not as the weight of the top part should keep it down, but I am not too sure. Thanks. Steve. If you don't put them on, the trumpets may come out of their sockets in the rear arms or dislodge from the bags. Usually when you are on a bumpy road. |
Author: | knuts2au [ Sun May 06, 2007 10:38 pm ] |
Post subject: | Trailers |
I have made 2 trailers from rear subframes for work, one is a dry one for an esky, the other is a hydro for a mobile speaker box. The hydro one runs shocks instead of the springs as it was two bouncy before, only problem is a small leak on one side so have to pump it up every 12months.Will post some pic's soon. PeterN |
Author: | drmini in aust [ Mon May 07, 2007 6:50 am ] |
No need to run helper springs, the pressure will keep the strut in the arm socket. There are rebound rubbers under the arm, keep them. I agree shocks are a good idea. ![]() |
