It is currently Sat Jul 26, 2025 12:27 am
How many jerry cans do you own?
0, I'm an optimist 27%  27%  [ 4 ]
1, you live and learn 20%  20%  [ 3 ]
2, I'm slow a learner 33%  33%  [ 5 ]
3+, these things will become collectibles one day! 20%  20%  [ 3 ]
Total votes : 15
 Post subject: Mini's and Jerry cans
PostPosted: Fri May 04, 2007 7:35 pm
Slow-Po
After being away for 2 weeks, a lot of the BP ultimate evaporated on the moke. :shock: There wasn't much there to begin with before I left, but more than enough to get me further than the 2 kms I managed to travel today.
The ticking sound that started about a kilometre had me worried it was a bearing, closer inspection revealed it was the petrol pump, and that I had just missed pulling into the nearby petrol station. I was lucky to be able to pull over safely and then go for a short stroll.... :)
PostPosted: Fri May 04, 2007 7:55 pm
No excuse for running out in a Moke. Take off the big cap and peer in. If you can see steel, you need to fill. :lol:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri May 04, 2007 7:58 pm
I've bought two jerry cans, during fuel outages.
One time I held the Mini on starter in 1st gear (not enough torque in 2nd) for a hundred M or so to get to the servo; it was raining outside.
PostPosted: Fri May 04, 2007 8:03 pm
I think you need to install the cork gasket between the cap and the neck - stops the evaporation. I have a plastic 5 litre jerry for that very purpose
PostPosted: Fri May 04, 2007 8:06 pm
Slow-Po
Agreed, but I was in a rush to get to supercheap to buy a battery before they closed. I failed. :)
I like the cork gasket idea, I will take a closer look at the cap and possibly head down to bunnings.
PostPosted: Fri May 04, 2007 9:58 pm
On the last test run in the Countryman before it passed rego,
started it up, but could still hear the "tick" of the electric fuel pump.
I look at #1 son, he looks back at me & says "must be nearly empty"
(picks these things up quickly)
Go for a run around the block anyway.
Just over half way, engine cuts out so I slip into neutral & coast into our street, then the boy hops out while we're still moving & pushes us until we're back in the driveway. And of course, all three jerry cans are empty :x
PostPosted: Fri May 04, 2007 11:54 pm
What a moment for You and #1 Son
Who's fault was it the the Gerry's wern't Full...YOU :lol:
2 but both empty :shock:
PostPosted: Sat May 05, 2007 12:21 am
My family owns 6. :shock:
4 metal, my plastic all 25 litres each.
2 for diesal msotly for the tractor but can be used in either 4WD but general not needed as they have 100L fuel tanks anyway and are very economical.
And 4 for the Mini's and the Merc. Mostly for the Mini's haha.
Now we're doing 2 with 95, and 2 with 98, eg 2 for my car, and 2 for any other car or mine plus octane booster.
PostPosted: Sat May 05, 2007 12:58 am
I want an lpg jerry can...
