Hey guys,
My little van is getting closer to being ready for rego. I believe it to be a one owner van (rego wise), with only one other brief owner - he threw out the back seat and did a bad respray and sold it to me.
I have the ACT rego papers and plates “YAB-***” – seems to indicate an early act plate. On the papers it’s listed as a station wagon. I don’t know the history of aussie vans and back seats, only that they were done by the dealers with the side windows.
If mine was done by a dealer and rego’d in ACT, and now after 8 years of being off the road and looking at NSW rego – would they pass it as a four seater if it had the original fitted rear seat?
As mentioned, the temp owner threw the back seat out as it was old and torn etc and didn’t like it. So I’ve got three options as far as I can see.
1) Have no back seat and get rego (possible fail for having the chassis cut for the seat?) – look at getting one engineered later.
2) Bolt in the seat in the pick (the bolt holes line up with the rises in the floor, and put plates underneath). If this works and passes, look at doing 3 later.
3) Get some pics from the web and you guys and construct an original aftermarket look-a-like.
From what I’ve been told, the Aussie dealer conversion has no rear seat belts.
Any info / advice would be greatly appreciated. I guess the moke owners out there may have had the same problems with factory 2 seaters?
The main thing I don’t like with the current seat is that it sites quite high, no adults or their heads are on the roof. Also, the internal door hinge bracket is so close to your head in the back..
Let me know what you think,
Cheers, Tom.
