It is currently Fri Jul 18, 2025 5:49 pm
PostPosted: Tue Nov 30, 2004 10:06 am
Hi,
Does anybody know what to look at when identifying a geniune Mark 2 Cooper S gearbox. There is the 22G1128 cast number what else is there to look for.
Thanks
PostPosted: Tue Nov 30, 2004 10:09 am
I can tell you its a 4 sycro remote Box Mines going onto my Mk2 Block
PostPosted: Tue Nov 30, 2004 12:07 pm
do not know no one asked me that before
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Nov 30, 2004 12:53 pm
:D
3.44:1 diff ratio, Diff output flanges to suit Hardy Spicer needle roller inner unis, 1st motion shaft and laygear are different, all other gear box parts are the same as a non S box including the common 4 synchro case. If it's a genuine Mk2 S case then the original engine number 9FXEY etc should be stamped in the area below the starter motor on a raised boss on the front of the case.
Regards
RonR
