ID Mark 2 Cooper S Gearbox
https://www.ausmini.com/forums/viewtopic.php?f=2&t=3151
Author:  Gezo [ Tue Nov 30, 2004 10:06 am ]
Post subject:  ID Mark 2 Cooper S Gearbox
Hi,
Does anybody know what to look at when identifying a geniune Mark 2 Cooper S gearbox. There is the 22G1128 cast number what else is there to look for.
Thanks
Author:  gafmo [ Tue Nov 30, 2004 10:09 am ]
I can tell you its a 4 sycro remote Box Mines going onto my Mk2 Block
Author:  1380 yellow devil [ Tue Nov 30, 2004 12:07 pm ]
do not know no one asked me that before
Author:  miniron [ Tue Nov 30, 2004 12:53 pm ]
:D
3.44:1 diff ratio, Diff output flanges to suit Hardy Spicer needle roller inner unis, 1st motion shaft and laygear are different, all other gear box parts are the same as a non S box including the common 4 synchro case. If it's a genuine Mk2 S case then the original engine number 9FXEY etc should be stamped in the area below the starter motor on a raised boss on the front of the case.
Regards
RonR
