Problems installing pinion https://www.ausmini.com/forums/viewtopic.php?f=2&t=31543 |
Author: | Booglie [ Tue May 08, 2007 5:09 pm ] |
Post subject: | Problems installing pinion |
I'm trying to get the pinion from an A+ into an A gearbox, but the bearing retainer is a little is to small, is it possible to fit the retainer from an A+ box into the A box |
Author: | jbeenz [ Tue May 08, 2007 6:51 pm ] |
Have you changed diff ratio? if you are going to a taller diff (ie smaller number like 3.7:1 to a 2.9:1) the pinion will be bigger, you can mill the retainer with a file, or a drum sander on a drill is great. |
