It is currently Wed Aug 06, 2025 2:04 pm
 Post subject: cleaning carbs
PostPosted: Sun May 13, 2007 8:19 pm
Any one got a magic formula to clean su carbs,
I have tried carb clean, brake clean, nappy san, kero, mag cleaner,
I would like to dip them in some sort of soultion and clean them sparkly clean.
My dad had a formula to clean alui heads which worked really well but i cannot remember it and unfortuntley he his no longer with us.
Any one got a potions i could try
Spent half a day just cleaning one carb
Thanks
Kiwiinwgtn
PostPosted: Sun May 13, 2007 8:24 pm
A mix of ammonia and water does wonders to aluminium and brass. Dip them in and watch them clean up in under half an hour.
Hideously important to wash all the ammonia off after cleaning.
Works a treat on old carbs covered in buildup.
PostPosted: Mon May 14, 2007 12:30 am
caustic???
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon May 14, 2007 2:50 am
mad-mk1 wrote:
caustic???
I think it attacks alloys.
PostPosted: Mon May 14, 2007 6:51 am
No it's not caustic, just smelly. You put it in for no more than half an hour and rinse, rinse, rinse.
Motorcycle shops do this for manky motorcycle carburettors, and have been doing so for years.
But yes, I must stress that you rinse them off thouroughly after taking them out in tap water to stop the process. Brass will turn black if left to oxidise in the open air.
I wonder if that is what your father used to use?
PostPosted: Mon May 14, 2007 8:51 am
Mick wrote:
A mix of ammonia and water .
what ratio?
PostPosted: Mon May 14, 2007 9:38 am
I think you will find carby specialists use a low concentration of phosphoric acid to clean carbies, mag wheel etc. It is an acid, so threat it with respect.
PostPosted: Mon May 14, 2007 1:25 pm
Not sure about carby use, but the engine reconditioing game used cresylic acid to decarbonise aluminium alloy pistons etc when I worked there. :wink:
PostPosted: Mon May 14, 2007 1:32 pm
GT wrote:
what ratio?
I believe I used 30 percent last time i did it (2002). All it does is slow down the process based on the water mix so you can start low and ramp it up. I've got a few bits of ally to treat from the Cooper, so I can give it a go in the next few days and post the results.
Yes it is corrosive to copper, zinc, aluminium and their alloys in it's pure form. the household stuff is very very dilute yet does a great job. I'll pick some cloudy ammonia up from bunnings and let you know.
EDIT: I've got some parts bubbling away in a small bucket as we speak, will let you know soon the result.
PostPosted: Mon May 14, 2007 2:23 pm
Nulon carby/throttlebody cleaner is what I use. If it doesn't get it off the first time round, leave it soak for a few mins then hit it again.
PostPosted: Mon May 14, 2007 3:18 pm
Yep good stuff, has other uses too. A whiff thru the plughole starts my recalcitrant Victa 4 stroke mower when winter is gone and it still wants to sleep.:)
PostPosted: Mon May 14, 2007 5:33 pm
thanks Mick
dad must have used something simular, i know it came from mums laundry..
I will try some over the weekend
Post the results of your bucket exsperiment
Ta
B
PostPosted: Mon May 14, 2007 5:58 pm
I gave the ammonia a go, and the results aren't what i remembered...
Two very oxidised parts were dropped in two solutions, 1/3 Ammonia/Water and 100 Percent Ammonia. They were as they came off the car, not a bit of cleaning was done to the parts prior to dropping them in.
After two hours, the first part (ally rear subframe mount) which was literally covered in white aluminium oxide was clean and normal as if the part had been used every day. It is ready to be painted but it is in no way shiny. The other part (SU float bowl lid) was in a similar state after a shorter period in the 100 percent solution. Although it is nice and clean again and in fact ready to bolt on, it is not scoured clean.....
So the results are OK, but not as clean as i expected, something has changed. The wifey(pHd BSci Chem) reckons the dilution of the supermarket grade ammonia is too great. I reckon she might know what's what... It removed every last scrap of petrol residue clinging to the lid. There's not a bit left. it might be good for cleaning up the fuel bowls with residue in the bottom.
i will probably do this again to the entire carb prior to storing it away. At 1.40 for 1 litre of ammonia from coles it is cheaper than carb cleaner with similar results. A nice simple way of removing oxidised Aluminium without the scubbing anyway.
I'm gonna leave one out overnight in the now mixed 60 persent solution anyhoo and see what happens.
Front bowl
Rear treated bowl
PostPosted: Mon May 14, 2007 7:52 pm
looking good, get the wife to get the text books out and make us up a magic solution.. could be your retirement fund or car money fund,
what do they use in the carb repair shops i wonder
PostPosted: Mon May 14, 2007 8:30 pm
If you really want ally bits clean, put on some heavy gloves and clean the bits with paint stripper, giving it a good scrubbing in with a toothbrush or steel wool. . .yes, the paint stripper does contain some caustic, so I wouldn't leave it on there for hours or anything but this is a one-step way of removing grease, oxidation and any paint that might be on there. Rinse the parts really well with water afterwards and blow them dry with compressed air.
