V.I.N Number
https://www.ausmini.com/forums/viewtopic.php?f=2&t=31653
Author:  Fiji [ Fri May 11, 2007 12:39 pm ]
Post subject:  V.I.N Number
i have an id plate in the engine bay but can't make out the complete Vin Number. is it stamped somewhere else on the car .. Or is that the Chas Number.. where do i start looking?
Author:  sports850 [ Fri May 11, 2007 12:40 pm ]
I'm assuming it's a pre 69 roundnose ? They don't have "VIN" numbers as such since they were before compliance plates , they use the body number instead which is what became the vin number really .
EDIT , just re-read your post , the body number will be either stamped on the firewall or the radiator shroud and should match whats on the ID plate (unreadable on yours ?)
Author:  Fiji [ Fri May 11, 2007 1:46 pm ]
i have found 2 numbers stamped to the engine bay.to the left side of the engine bay. the id plate was covering one
the vin number has about 6 numbers stamped on the id plate, the rest just blank..
Author:  odd [ Fri May 11, 2007 9:28 pm ]
the number on the radiator shroud wouldn't be exactly the same as the number on the firewall and ID plate would it? mine isnt anyway. my firewall number matches the ID plate however the number on the radiator shroud is about 100 out.
Author:  odd [ Fri May 11, 2007 9:41 pm ]
ive found an old post that i made when i discovered that the radiator shroud number didn't match the ID plate. It migh be an interesting read.
http://www.ausmini.com/forums/viewtopic ... sis+number
Author:  Fiji [ Sat May 12, 2007 10:19 am ]
thanks for that :
i thinki may be in the same bout as this guy, my id plate reads YMA2S1 and then 8Y/U/H13517
red_mini_mad wrote:
I am not sure, the complaince plate reads
8Y/U/H YMA2S1
my thinking is it may be a 850 (this web site seems to indicate this http://www.minis.com.au/CAR_TYPE.HTM).. no stamp on shroud
Questions.
is there any way to read the VIN number off some other part of the vehicle i have old receipts for my car: the VIN number is 16 numbers long, is this correct. i would like to be abl to confirm this.... my id plate only reads YMA2S1..
My two stamped numbers on the firewall are not listed on the id plate, there is no match anywhere i can see.
anyone can help would be sweet...
Author:  sports850 [ Sat May 12, 2007 10:50 am ]
Yes that's an 850 number and the body number is all you need for the vin . At some stage in it's life someones quoted YMA2S1 then the car number (BMC reference number) then the body number as they are all listed on the plate . I'll get back to you later with an approximate age from the engine number , what is the number on the firewall ?
Author:  Fiji [ Sat May 12, 2007 11:34 am ]
firewall numbers are 2.:
Under ID Plate =
I beleive this is the body number... its the only visible number on the engine bay once the plate is put back on. however the last number is lightly stamped...
You wrote: At some stage in it's life someones quoted YMA2S1 then the car number (BMC reference number) then the body number as they are all listed on the plate
On an old receipt they have listed the VIN as all the numbers above YMA2S1
My question is why aren't either of the body numbers listed on the plate,,, or does this not happen? Cheers. this is starting to make a little more sense.
Author:  sports850 [ Sat May 12, 2007 2:07 pm ]
I'm not even going to hazard a guess as to what's going on with the numbers on the firewall compared to the ID plate but I can tell you it's a September 1964 built 850 if that helps .
Author:  Fiji [ Sat May 12, 2007 2:40 pm ]
thats good to know. thnaks for the lookup 850..
