Earth strap flying free as a bird??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=31690
Author:  speedy [ Sat May 12, 2007 6:26 pm ]
Post subject:  Earth strap flying free as a bird??
I was pulling bits off my moke today and found the following. Shouldn't the fact the earth isn't bolted down be causing me grief? :?
Author:  Hanra [ Sat May 12, 2007 6:27 pm ]
Its not good, but the engine can be grounded through other items..... throttle cable/accel cable. But all the other items are NOT designed to handle any current.
Author:  willy [ Sat May 12, 2007 6:28 pm ]
There's lots of other earthing points, but the strap is probably the best point... it's very direct.
Author:  aaron [ Sat May 12, 2007 6:28 pm ]
it will eventually, unless there's a second one connected. undo nearest flywheel cover bolt, attch and do it up. solved :wink:
Author:  speedy [ Sat May 12, 2007 6:29 pm ]
Thanks guys. It's not going anywhere for a while, and I'll get bolted down before it does. 8)
Author:  Mike_Byron [ Sat May 12, 2007 7:04 pm ]
When you do - polish both surfaces with coarse emery or a file so there is good metal to metal contact
In fact, its not a bad idea every twelve months or so to re-establish all the metal to metal contacts on a car. The givaway sign that its due is a yellowing of the lights.
Author:  speedy [ Sat May 12, 2007 7:07 pm ]
Thanks for the tip Mike, will do as suggested.
Look what else I found whilst I was under there, I don't know much, but I know that doesn't look right. Looks like dental floss holding it together. :lol:
Author:  Hanra [ Sat May 12, 2007 7:22 pm ]
Good time to fit 2 of these....
Author:  Morris 1100 [ Sat May 12, 2007 7:25 pm ]
Or one of these......
Author:  Hanra [ Sat May 12, 2007 7:27 pm ]
Or just get ur self one of these......
Author:  speedy [ Sat May 12, 2007 7:30 pm ]
Agreed, what's the part called?
Author:  Hanra [ Sat May 12, 2007 7:44 pm ]
http://www.minispares.com/Product.aspx?pid=35285
Author:  speedy [ Sat May 12, 2007 7:47 pm ]
Thanks mate. 8)
Author:  Mick [ Sat May 12, 2007 9:18 pm ]
Cotton reel rubber mounts can be had from Blackwoods and the like any day of the week if there's one close by, they're used a lot in industry as well.
Author:  awdmoke [ Sat May 12, 2007 10:03 pm ]
Or any exhaust place (except they'll have metric threads)
