Gear Problems https://www.ausmini.com/forums/viewtopic.php?f=2&t=3171 |
Author: | djhaddo1 [ Wed Dec 01, 2004 8:02 am ] |
Post subject: | Gear Problems |
Hi All, I have a problem with my gearbox. ![]() Whenever 1st is selected, as soon as you release the clutch it pops back into neutral. All other gears are fine, it just means you from have to drive off in second which is somewhat of an inconvenience for hillstarts for my poor old 998. Any ideas on the cause/remedy would be greatly apprecited. Dan |
Author: | min13k [ Wed Dec 01, 2004 10:55 am ] |
is it rod or remote change ?? makka |
Author: | djhaddo1 [ Wed Dec 01, 2004 11:14 am ] |
Remote I'm assuming as it is still original. |
Author: | min13k [ Wed Dec 01, 2004 12:07 pm ] |
hmmmmmm maybe the ball on the bottom of the shift has worn or the cup on the rod in the remote and is not allowing it to engage properly makka |
Author: | djhaddo1 [ Wed Dec 01, 2004 1:05 pm ] |
Cheers Makka, ![]() Dan |
Author: | min13k [ Wed Dec 01, 2004 1:06 pm ] |
no worries makka |
Author: | djhaddo1 [ Thu Dec 02, 2004 8:05 am ] |
Had a look last night, pulled apart the shifter and to my limited mechanical exp it seemed ok. Reassembled and first is useable IF you push down while selecting. Still does not guarantee it though. I'll probably just take her to Ivan in Castle Hill when I have a free weekend and get him to look. Dan |
Author: | 68matic [ Thu Dec 02, 2004 10:40 am ] |
can you hold the stick in 1st as you start off or does it pop out at the bottom as well |
Author: | djhaddo1 [ Thu Dec 02, 2004 11:07 am ] |
Quote: can you hold the stick in 1st as you start off
or does it pop out at the bottom as well Tried holding it in. Refuses to stay. It does seem to be a worn part in the remote cause it will occasionally engage properly. |
Author: | 1380 yellow devil [ Thu Dec 02, 2004 12:17 pm ] |
I have had the gear stick boot causeing it to slip out once. It could also be worn syncro in box???? |
