It is currently Thu Aug 14, 2025 5:07 am
 Post subject: subframes
PostPosted: Mon May 14, 2007 12:56 am
hey gang
mini hydro subframes, rears, whats teh difference between normal run of teh mill ones and 67cooper s ones??
are there any
other tahn step drums???
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon May 14, 2007 7:52 am
The Cooper S/Clubby GT hydro bags are a bit stiffer. And they have 5/8" rear wheel cylinders not 3/4". That's it. :wink:
I run a Clubby GT front one with a MiniMatic/Mini K rear, it works fine. 8)
PostPosted: Mon May 14, 2007 11:06 am
so to most it would go unnoticeable?
how hard /expensive is it to change to the 5/8th size?
thx doc
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon May 14, 2007 11:51 am
Same price for the cylinders actually.
i did hear that the brake bias valve was springed slightly differently as well to suit the smaller rear cylinders? Can anyone confirm this (I seem to remember Vizard carping on about it somewhere)?
PostPosted: Mon May 14, 2007 1:18 pm
There are various limiting valve pressures that were used here in Oz but you could throw a hanky over the lot, there's not much in it.
After 40 years they all look the same.
Keith Calver did a writeup once on how to make them adjustable. 8)
PostPosted: Mon May 14, 2007 1:28 pm
but regency wouldnt notice...
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon May 14, 2007 2:43 pm
You do want the smaller break cylinders in the drums, with discs, the rears tend to lock up.
Users browsing this forum: No registered users and 184 guests
