Broke a Head bolt in Morris https://www.ausmini.com/forums/viewtopic.php?f=2&t=3177 |
Page 1 of 2 |
Author: | gafmo [ Wed Dec 01, 2004 1:17 pm ] |
Post subject: | Broke a Head bolt in Morris |
![]() ![]() ![]() ![]() Not a good Day today...Recieved my delivery of gaskets from my normal source this morning Late and then missing the Manifolt gasket ![]() So i'll do the rest untill it arrives.... ![]() Torqe it up in 5's to 40 and then 2's...all hunky dorry. just one seemed to be going a little further... ![]() ![]() I think I'll go for a swim and cool off ![]() ![]() |
Author: | danidad [ Wed Dec 01, 2004 1:26 pm ] |
can you grab it, or is it an "easy out" job. |
Author: | gafmo [ Wed Dec 01, 2004 1:31 pm ] |
Not sure I havent taken the head back off yet, just untorqed the head. I'll have a look in a Minute ![]() |
Author: | J_A_M [ Wed Dec 01, 2004 1:33 pm ] |
oh dear......... ![]() |
Author: | gafmo [ Wed Dec 01, 2004 1:50 pm ] |
Not Happy Jan ![]() 50 / 50 chance and I lucked out ![]() |
Author: | Wombat [ Wed Dec 01, 2004 3:13 pm ] |
bugga ![]() |
Author: | gafmo [ Wed Dec 01, 2004 3:15 pm ] |
I'f I have to pull this engine out again its going to be replaced with a 1275 ! |
Author: | drmini in aust [ Wed Dec 01, 2004 4:18 pm ] |
Go down to Lee Bros in Dunlop St, Nth Parramatta and take a good bolt with you. You want Grade 8, 3/8" UNC x wharever the length is. Or, chuck `em all away and fit studs & nuts (better). ![]() You can pinch all the ones from your other 998? motor. ![]() If you do this, only use 40-42lb/ft torque. |
Author: | gafmo [ Wed Dec 01, 2004 4:22 pm ] |
Hang on good news ![]() |
Author: | gafmo [ Wed Dec 01, 2004 4:24 pm ] |
I put a hole in a door for this ![]() sprayed a little WB40 on it and she just unwound..go figure. I'll be poping down to Lee's tomorrow and getting a hole new set of bolts. Boy am I lucky...not so angry now ![]() |
Author: | drmini in aust [ Wed Dec 01, 2004 4:26 pm ] |
Antique bolt. ![]() ![]() At least on my Fiat, the bastards just used to stretch.. ![]() |
Author: | 1310/71 [ Wed Dec 01, 2004 4:33 pm ] |
Post subject: | Hole in a door |
Hi Gafmo, Mini door or internal hollow door? If the latter, JAM could help, he's experienced at renovations! Glad to see it came out, I was about to offer my ezi-outs if you needed them. Kevin. |
Author: | gafmo [ Wed Dec 01, 2004 4:58 pm ] |
Hollow Door I was wonderingwhat you were on about.. ![]() ![]() Doc I'm going to take both sets down with me just incase they can not do the other.....I have an inteview in the city so the bolt and all are comeing with me..LOL...Just so relieved no motor has to come out ![]() |
Author: | Chris [ Wed Dec 01, 2004 5:34 pm ] |
gafmo wrote: I put a hole in a door for this
sprayed a little WB40 on it and she just unwound..go figure. I'll be poping down to Lee's tomorrow and getting a hole new set of bolts. Boy am I lucky...not so angry now ![]() Do what Doc says and put studs and nuts on it. The bolts are to long and eventually twist and break. The nut/stud arrangement will not do that. |
Author: | drmini in aust [ Wed Dec 01, 2004 6:37 pm ] |
Chris wrote: gafmo wrote: I put a hole in a door for this sprayed a little WB40 on it and she just unwound..go figure. I'll be poping down to Lee's tomorrow and getting a hole new set of bolts. Boy am I lucky...not so angry now ![]() Do what Doc says and put studs and nuts on it. The bolts are to long and eventually twist and break. The nut/stud arrangement will not do that. Probably not helped by the fact we took another .050" off the head.. ![]() Yeah, I like studs too! Stock Mini ones are OK, but if U got money to burn, buy ARPs. ![]() |
