It is currently Wed Jul 23, 2025 12:29 pm
 Post subject: Dyno'd
PostPosted: Wed May 16, 2007 1:23 pm
Just had the LS dyno'd this morning and after getting the SU needle changed and new plugs & leads fitted, the motor is running sweet as...
The LS is getting 30Kw or 40.23Hp @ 6000rpm to the wheels from a 1030cc motor. When I get another head done up the mechanic says I should get around a 40% increase in power.... :D
PostPosted: Wed May 16, 2007 1:46 pm
That's a top effort from 1030 mate. Keep up the good work. Great figure and good luck with this new head your talking about hope t all goes to plan for you.
PostPosted: Wed May 16, 2007 1:49 pm
what sort of SU are you running?
PostPosted: Wed May 16, 2007 1:50 pm
1.75 HS6..
PostPosted: Wed May 16, 2007 1:59 pm
Hmmm... big carb for a little engine. Obviously working well though :)
PostPosted: Wed May 16, 2007 2:15 pm
Had to put the bigger carb on awdmoke because I just couldn't get it to run right with the 1.50 SU...
But yes, the bigger one works very well and still get around 26+mpg running around town and just over 30+mpg on longer runs...
