It is currently Sat Jul 26, 2025 7:56 am
 Post subject: remote brake booster
PostPosted: Wed May 16, 2007 10:41 pm
Hey is anybody using a remote brake booster?
PostPosted: Wed May 16, 2007 11:44 pm
Not me (yet - need discs first. One day...), but lots and lots of people are. :D The most common fitment is a PBR VH44 (or sometimes VH40) fitted on the driver's side. I'm sure there'd be some photos around in the galleries, or someone else can post here.. Basically, you just mount it over/beside/behind the clutch.
I've heard rumours that there are actually three different pressures available in VH44's - they've been used in everything from Minis to old Holdens. Three pressures (different diaphragms), three different levels of assistance. I could be wrong, but it'd probably pay to source one from a Mini or Mini shop, although they are available elsewhere (could try Repco..?). There are also other types available, but I'd expect that they'd probably be a little dearer, as they tend to be replicas of the boosters that were originally put into S's (can't remember if that was standard, factory or dealer fit - someone else will know). Either one should do the job for you. :wink:
Hey, found a pic! 5th post down, 2nd photo, driver's side, little black booster mounted next to the engine in Peter1's very nice Cooper S. http://www.ausmini.com/forums/viewtopic ... c&start=15 :D
PostPosted: Thu May 17, 2007 11:54 am
the PO of my 850 put a booster in the boot mounted to the underside of the parcel shelf. Does not get more remote than that. It is still there and works too, despite having drums rather than discs. He also put a "vacuum reservoir" mounted under the rear seat on the drivers side, his reasoning being that if you lost the engine, you still had enough vacuum for a couple of operations of the brakes.
michael
