It is currently Tue Jul 22, 2025 1:44 am
PostPosted: Wed May 16, 2007 6:30 pm
If anyone could give me a semi-definate year of my vehicle it would be much appreciated.
Hmmmmmm.......Is it safe to put the VIN and engine number on here?
regards
Odd
PostPosted: Wed May 16, 2007 6:32 pm
High heel ninja
regards
Odd
i can't see why it would'nt be safe, plenty of other have in the past.
Doogie
PostPosted: Wed May 16, 2007 6:40 pm
If you're not keen, there are dates (MM/YY) on the cover plate of your wiper motor, on the dizzy which are easy to look at. Usually you can be lucky enough to have the original wiper motor, but often the dizzys are swapped out. Worth a look anyway.
Add a couple of months and you can be pretty close to the date.
PostPosted: Wed May 16, 2007 7:19 pm
regards
Odd
I would not advise sticking you numbers on the web. Just give the first bit of the numbers and stick a * over the last two numbers.
A Deluxe should have a serial number like... YMA2S2 123**
The engine number should be like... 9Ya/Ta/H 128**
The deluxe was built between 1965 and 1969.
PostPosted: Wed May 16, 2007 8:10 pm
Ok the numbers are:
YMA2S2 319**
9YA/Ta/H 332**
I guess that means it is a deluxe
Users browsing this forum: Majestic-12 [Bot] and 92 guests
