early metro ball joints
https://www.ausmini.com/forums/viewtopic.php?f=2&t=31834
Author:  mini-dunger [ Thu May 17, 2007 7:45 am ]
Post subject:  early metro ball joints
Hi all
Karcraft just told me they will not be getting any early metro ball joints until atleast late june early july. Does anyone know of anywhere I may be able to get these sooner.
Thanks in advance
Michael
Author:  minimetoy [ Thu May 17, 2007 8:45 am ]
MG Heritage at smithfield NSW.
Dan
Author:  JC [ Thu May 17, 2007 2:01 pm ]
Epay.co.uk
Author:  miniboy1962 [ Thu May 17, 2007 4:31 pm ]
I got a quote from MG Heritage and it was $45 each... So...
Is this what i need?
It is so confusing - Austin, Rover, Metro, Turbo...
http://cgi.ebay.co.uk/AUSTIN-METRO-UPPE ... dZViewItem
Author:  mini-dunger [ Thu May 17, 2007 9:21 pm ]
Post subject:  ball joints
yes, you need before 84 ones
Author:  minimetoy [ Thu May 17, 2007 9:37 pm ]
Not sure if what you need? The difference in the two ball joints is the diameter of the taper.
So if you are using mini suspension you should be able to use mini ball joints???? because the taper will fit into the upper arm and the lower arm.
Dan
Author:  mini-dunger [ Thu May 17, 2007 9:47 pm ]
no they are totally different,
metro ball joints have no shims and a more of a bolt type arrangement that screws into the uprights.
early metro ones have a smaller taper which suits the mini control arms. the later metro ones have a thicker ball joint shaft with a different taper.
Author:  simon k [ Thu May 17, 2007 10:20 pm ]
Post subject:  Re: ball joints
so they're throw away whe they're worn?
Author:  drmini in aust [ Thu May 17, 2007 10:26 pm ]
Yes, like any other car... :wink:
