Which door to use? https://www.ausmini.com/forums/viewtopic.php?f=2&t=31854 |
Author: | henry the mini [ Thu May 17, 2007 6:28 pm ] |
Post subject: | Which door to use? |
I have two doors. The one or orriginaly on the car is fairly rusty but quite "straight" and i know this one fit the car. The other one got only suface rust but got quite a few dint and bump on it, also got a bit of surface rust inside the skinn. I dont know if this door will fit well on the clubby. Simple question, should i have the original one fixed (expensive) of used the spare one? Also does anyone know a mini friendly panel beater in Geelong? Thanks Louis |
Author: | doogie [ Thu May 17, 2007 6:34 pm ] |
Dents are easier to fix than rust. Doogie |
Author: | Joe [ Thu May 17, 2007 9:54 pm ] |
they are both clubbie doors yeah? otherwise, fitting morris doors to clubbies and vice versa is a bit of a challenge.. |
Author: | henry the mini [ Thu May 17, 2007 9:58 pm ] |
Joe wrote: they are both clubbie doors yeah? otherwise, fitting morris doors to clubbies and vice versa is a bit of a challenge..
Yep both clubby door, same year, just different probleme. Please Help me, all of you!!! ![]() |
Author: | simon k [ Thu May 17, 2007 10:21 pm ] |
I'd find a door that doesn't have rust OR dents... easy.... |
Author: | mad-mk1 [ Fri May 18, 2007 12:04 am ] |
post some pics mate, it might be easyer than u think cheers |
