Odd A+ Engine Number https://www.ausmini.com/forums/viewtopic.php?f=2&t=31889 |
Page 1 of 2 |
Author: | 9YaTaH [ Fri May 18, 2007 7:45 pm ] |
Post subject: | Odd A+ Engine Number |
Visited a new Ausmini member tonight....interesting, rivetted, aluminium engine tally plate on a small bore. B or PHM1270ET1088A .............AD............... BMC remanufactured engine??? |
Author: | miniimports [ Fri May 18, 2007 8:57 pm ] |
Post subject: | re engine number |
will be a aplus 998 engine,factory remanufactured as they generally start with the bhm number,as i occasionally get the 1275 version in the aplus's,quite common in the uk |
Author: | 9YaTaH [ Fri May 18, 2007 8:59 pm ] |
Post subject: | A+ |
Ohhhhh?? this engine had side plates....maybe I'm getting confused with A+1275....but, I thought all A+s were the later, no side plates, stronger block?? Hmmmmmmm ![]() |
Author: | Morris 1100 [ Fri May 18, 2007 9:06 pm ] |
The only engines without side plates were the non-Cooper S 1275. |
Author: | 9YaTaH [ Fri May 18, 2007 9:27 pm ] |
Post subject: | A+ 998 |
Morris 1100 wrote: The only engines without side plates were the non-Cooper S 1275.
Thanks Mike, 1100S only.....no side plates. So how young are A+ 998s ![]() |
Author: | drmini in aust [ Fri May 18, 2007 9:28 pm ] |
Post subject: | Re: A+ 998 |
9YaTaH wrote: Morris 1100 wrote: The only engines without side plates were the non-Cooper S 1275. Thanks Mike, 1100S only.....no side plates. So how young are A+ 998s ![]() 1980 on. ![]() As well as 1100S, there's all the others of course that ran that same block with no side plates. And the A+1275s as said. |
Author: | 9YaTaH [ Fri May 18, 2007 9:31 pm ] |
Wow ![]() |
Author: | drmini in aust [ Fri May 18, 2007 9:32 pm ] |
9YaTaH wrote: Wow
![]() We bought an old Clubby once that had an A+ 998 in. Painted yuk yellow it was... the motor that is. ![]() |
Author: | Morris 1100 [ Fri May 18, 2007 9:34 pm ] |
9YaTaH wrote: Morris 1100 wrote: The only engines without side plates were the non-Cooper S 1275. Thanks Mike, 1100S only.....no side plates. 1275 in Sprite, Midget, Austin America, Morris 1300, Allegro, Marina, Metro, Maestro, Montego, Mini, etc. had no side plates. By comparison they only made a handfull of 1275's with side plates. ![]() |
Author: | Morris 1100 [ Fri May 18, 2007 9:36 pm ] |
9YaTaH wrote: Wow They were cheaper to make. ![]() ![]() |
Author: | 9YaTaH [ Fri May 18, 2007 9:41 pm ] |
drmini in aust wrote: 9YaTaH wrote: Wow ![]() We bought an old Clubby once that had an A+ 998 in. Painted yuk yellow it was... the motor that is. ![]() Thanks Doc....was it VHT?? ![]() |
Author: | 9YaTaH [ Fri May 18, 2007 9:42 pm ] |
Morris 1100 wrote: 9YaTaH wrote: Morris 1100 wrote: The only engines without side plates were the non-Cooper S 1275. Thanks Mike, 1100S only.....no side plates. 1275 in Sprite, Midget, Austin America, Morris 1300, Allegro, Marina, Metro, Maestro, Montego, Mini, etc. had no side plates. By comparison they only made a handfull of 1275's with side plates. ![]() Mike.....are you saying MKI Cooper S non-thick flange was only a handfull ![]() |
Author: | slinkey inc [ Fri May 18, 2007 9:48 pm ] |
By comparison, I'd say he's saying 'yes'. It's the way to weed out Cooper S engine fakers. A lot of people say thier 1100S is an S motor which is a fair enough thing to say to non-mini people, as saying 1275 may not mean a lot. But to other mini people, it's known there is a big difference between S motors and non-S. What is the reason for the side plates? I had to take my breather sid eplate off and put an 850 one on (which is different, it looks different) and ran a rubber pipe with a tube as my breather. |
Author: | drmini in aust [ Fri May 18, 2007 9:53 pm ] |
The side plates are there to make it easy to remove or replace the cam followers. But on the 1275, they made the block stiffer by doing away with them. ![]() Downside is it's near impossible to swap cam with the motor in the car. |
Author: | 9YaTaH [ Fri May 18, 2007 9:54 pm ] |
Post subject: | Clutch |
slinkey inc wrote: By comparison, I'd say he's saying 'yes'.
It's the way to weed out Cooper S engine fakers. A lot of people say thier 1100S is an S motor which is a fair enough thing to say to non-mini people, as saying 1275 may not mean a lot. But to other mini people, it's known there is a big difference between S motors and non-S. What is the reason for the side plates? I had to take my breather sid eplate off and put an 850 one on (which is different, it looks different) and ran a rubber pipe with a tube as my breather. They were inspection plates and probably used in some service operations....but they do weaken the block. Same car has an interesting fault....when cold, no first and second, after warm up....1, 2, 3, 4.....the clutch master cylinder fluid level was about 30mm below the lip:shock: .....I suggested he lift his carpet and see if the Master has sprung a leak ![]() |
