It is currently Sun Aug 10, 2025 3:06 am
 Post subject: What year is this?
PostPosted: Sat May 19, 2007 9:04 pm
I need help finding out what year this is?
The numbers i have are
YMA2s2
30286
9YA/Ta/H/31278
1/LAKE GREEN/3
PostPosted: Sat May 19, 2007 9:49 pm
I would guess early 68. (may be very late 67)
Lake Green is in the Dulux book as a 67 colour but the numbers look like 68. They changed the wiper pattern in mid 68 and you car numbers are about 2000 cars before the changover point. At this time they were probably producing around 900 cars a month.
Check the dates on the dip switch, wiper motor, ignition switch, boot lock.
PostPosted: Sat May 19, 2007 9:53 pm
Thanks for that, will check tomorrow
PostPosted: Sun May 20, 2007 6:11 am
This should help you work out dates of models.
http://www.hotbricks.org.au/techtips/ar ... engine.txt
"Let us remove your "SHORTS"
