It is currently Fri Jul 18, 2025 5:18 pm
 Post subject: Oil leak problem
PostPosted: Sun Dec 05, 2004 9:52 pm
Hello ALL, I have just noticed that my 1098cc motor in my panel van is leaking oil.It looks like it is coming from where the block meets the gearbox.Is this a common problem or is it just a lemon????? :(
PostPosted: Sun Dec 05, 2004 9:59 pm
It's a Mini alright!
If it stops leaking oil, it must be out of oil!
Sorry I can't be more help.
PostPosted: Sun Dec 05, 2004 10:07 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
which end rad end or clutch end ??
makka
PostPosted: Mon Dec 06, 2004 6:41 am
What breathers are you running....Morris was leaking oil Before and after a rebuild and only had the breather via the rocker cover. On the weekend I also put one on the inspection plate Rad side and it not doing it any more 8)
