It is currently Sat Aug 02, 2025 1:32 pm
PostPosted: Sun May 20, 2007 5:58 pm
Hey all was wondering if anybody could help me with identifying my block.Its a 1275 without side plates with the number 12yd/ta/h16158.Am i even reading the right number,this is stamped where the head gasket sits.there is another number on the back that is12g G1279.Any help will be great thanks
www.hellonwheels.com.au
PostPosted: Sun May 20, 2007 6:05 pm
Non-Cooper S 1275 engine.
The other number is a part number.
PostPosted: Sun May 20, 2007 6:18 pm
Any idea of the age/time of build
PostPosted: Sun May 20, 2007 6:24 pm
It is from a 1275 LS, so I think it maybe a 77 - 78 vintage motor.
Cheers Pete
PostPosted: Sun May 20, 2007 6:29 pm
Wow awsome thanks so much guys thats a big help
PostPosted: Sun May 20, 2007 7:38 pm
It is not a 1275LS engine. :x :x :x
It is a Morris 1100S engine from about 5/69. :D
12 = 1275
Y = Australian (1275LS engine was fully imported and didn't have a Y)
D = 4th variation = 4.1 final drive ratio = Morris 1100S (1275LS didn't have this diff ratio)
Ta = Std ratio remote centre change.
H = High Compression
16158 = 15158th engine off the line. (one of the very last Morris 1100S) (The first engine was 1001)
The 1275LS has an engine prefix with 12H902UH, nothing like the 1100S. :wink:
PostPosted: Sun May 20, 2007 8:04 pm
We need to have like a sticky post of body numbers and engines numbers or something, cause this question gets asked quite a lot. Im sure there is enough information out there to create one post with all the info needed?
PostPosted: Sun May 20, 2007 8:34 pm
12 = 1275
High compression 'eh - that'd have been a good one back then. Would be a large journal crank too.
PostPosted: Sun May 20, 2007 8:37 pm
sweet engine...
PostPosted: Sun May 20, 2007 8:42 pm
cush wrote:
sweet engine...
yeah, but heavy condrods.... I've got some on my bench next top some S ones... 4 S ones weigh the same as 3 of those LJ ones
PostPosted: Sun May 20, 2007 8:44 pm
12 = 1275
Have you ever seen a low compression 1100S? :wink: As far as I know they were all high compression. (there is no low compression number listed in the books)
Crank journal dia. changed at engine number 10488.
PostPosted: Sun May 20, 2007 8:48 pm
Yes they called it high compression, but `twas only 8.8:1. hardly what I would call HIGH.. :lol:
Nothing some decent pistons won't fix though. :wink:
1100S with those heavy rods I would hardly call a `sweet engine' cush.
Maybe after the rods are hacked, the crank wedged, and the flywheel sent to Jenny Craig...
 Post subject: Wait
PostPosted: Sun May 20, 2007 8:53 pm
I always thought the 1100's were panned for having too heavy rods and too light pistons....so they tended to flap about :?
PostPosted: Sun May 20, 2007 9:02 pm
Morris 1100 rods and pistons were fine. But the 1100S rods weigh a bloody ton, these have a big lump on the caps for God knows what reason. When the A+ rods replaced, them, surprise!! No big lumps.. :wink:
PostPosted: Sun May 20, 2007 9:06 pm
skssgn and the doc of the heavy rod alliance wrote:
Why, grandma, what big rods you have....
All the better for reshaping with...
:P
