Another engine ID Question https://www.ausmini.com/forums/viewtopic.php?f=2&t=31941 |
Page 1 of 2 |
Author: | tom [ Sun May 20, 2007 5:58 pm ] |
Post subject: | Another engine ID Question |
Hey all was wondering if anybody could help me with identifying my block.Its a 1275 without side plates with the number 12yd/ta/h16158.Am i even reading the right number,this is stamped where the head gasket sits.there is another number on the back that is12g G1279.Any help will be great thanks |
Author: | Mick [ Sun May 20, 2007 6:05 pm ] |
Non-Cooper S 1275 engine. The other number is a part number. |
Author: | tom [ Sun May 20, 2007 6:18 pm ] |
Any idea of the age/time of build |
Author: | EST-071 [ Sun May 20, 2007 6:24 pm ] |
It is from a 1275 LS, so I think it maybe a 77 - 78 vintage motor. Cheers Pete |
Author: | tom [ Sun May 20, 2007 6:29 pm ] |
Wow awsome thanks so much guys thats a big help |
Author: | Morris 1100 [ Sun May 20, 2007 7:38 pm ] |
It is not a 1275LS engine. ![]() ![]() ![]() It is a Morris 1100S engine from about 5/69. ![]() 12 = 1275 Y = Australian (1275LS engine was fully imported and didn't have a Y) D = 4th variation = 4.1 final drive ratio = Morris 1100S (1275LS didn't have this diff ratio) Ta = Std ratio remote centre change. H = High Compression 16158 = 15158th engine off the line. (one of the very last Morris 1100S) (The first engine was 1001) The 1275LS has an engine prefix with 12H902UH, nothing like the 1100S. ![]() |
Author: | Hanra [ Sun May 20, 2007 8:04 pm ] |
We need to have like a sticky post of body numbers and engines numbers or something, cause this question gets asked quite a lot. Im sure there is enough information out there to create one post with all the info needed? |
Author: | simon k [ Sun May 20, 2007 8:34 pm ] |
Morris 1100 wrote: It is not a 1275LS engine.
![]() ![]() ![]() It is a Morris 1100S engine from about 5/69. ![]() 12 = 1275 Y = Australian (1275LS engine was fully imported and didn't have a Y) D = 4th variation = 4.1 final drive ratio = Morris 1100S (1275LS didn't have this diff ratio) Ta = Std ratio remote centre change. H = High Compression 16158 = 15158th engine off the line. (one of the very last Morris 1100S) (The first engine was 1001) The 1275LS has an engine prefix with 12H902UH, nothing like the 1100S. ![]() High compression 'eh - that'd have been a good one back then. Would be a large journal crank too. |
Author: | cush [ Sun May 20, 2007 8:37 pm ] |
sweet engine... |
Author: | simon k [ Sun May 20, 2007 8:42 pm ] |
cush wrote: sweet engine...
yeah, but heavy condrods.... I've got some on my bench next top some S ones... 4 S ones weigh the same as 3 of those LJ ones |
Author: | Morris 1100 [ Sun May 20, 2007 8:44 pm ] |
skssgn wrote: Morris 1100 wrote: It is not a 1275LS engine. ![]() ![]() ![]() It is a Morris 1100S engine from about 5/69. ![]() 12 = 1275 Y = Australian (1275LS engine was fully imported and didn't have a Y) D = 4th variation = 4.1 final drive ratio = Morris 1100S (1275LS didn't have this diff ratio) Ta = Std ratio remote centre change. H = High Compression 16158 = 15158th engine off the line. (one of the very last Morris 1100S) (The first engine was 1001) The 1275LS has an engine prefix with 12H902UH, nothing like the 1100S. ![]() High compression 'eh - that'd have been a good one back then. Would be a large journal crank too. ![]() Crank journal dia. changed at engine number 10488. |
Author: | drmini in aust [ Sun May 20, 2007 8:48 pm ] |
Yes they called it high compression, but `twas only 8.8:1. hardly what I would call HIGH.. ![]() Nothing some decent pistons won't fix though. ![]() 1100S with those heavy rods I would hardly call a `sweet engine' cush. Maybe after the rods are hacked, the crank wedged, and the flywheel sent to Jenny Craig... |
Author: | 9YaTaH [ Sun May 20, 2007 8:53 pm ] |
Post subject: | Wait |
drmini in aust wrote: Yes they called it high compression, but `twas only 8.8:1. hardly what I would call HIGH..
![]() Nothing some decent pistons won't fix though. ![]() 1100S with those heavy rods I would hardly call a `sweet engine' cush. Maybe after the rods are hacked, the crank wedged, and the flywheel sent to Jenny Craig... I always thought the 1100's were panned for having too heavy rods and too light pistons....so they tended to flap about ![]() |
Author: | drmini in aust [ Sun May 20, 2007 9:02 pm ] |
Morris 1100 rods and pistons were fine. But the 1100S rods weigh a bloody ton, these have a big lump on the caps for God knows what reason. When the A+ rods replaced, them, surprise!! No big lumps.. ![]() |
Author: | cush [ Sun May 20, 2007 9:06 pm ] |
skssgn and the doc of the heavy rod alliance wrote: Why, grandma, what big rods you have....
All the better for reshaping with... ![]() |
