It is currently Sun Aug 03, 2025 6:54 pm
 Post subject: Found a spare wire
PostPosted: Tue May 22, 2007 5:56 pm
Had the dash off of Ribena lately and I've found a wire that seems to be 'spare'.
It's white with a black trace - the end has an insulated connector.
I've tried to find what it's for from a few wiring diagrams but no luck.
Maybe a previous owner did something and removed the accessory before selling the car.
Your thoughts??????
Hooroo
Rod Image
PostPosted: Tue May 22, 2007 6:17 pm
White with a Black trace is usually an ignition wire between the coil and distributor.
Just a guess but could be a sensing wire for the later 3 instrument Clubman voltage sensing tacho????
RonR
PostPosted: Tue May 22, 2007 6:19 pm
Possibly a hidden kill switch ??? Check the wires to the coil and see what colour they are .
PostPosted: Tue May 22, 2007 6:28 pm
White/black I think goes to the coil, so is probably a tach sense wire. It's perfect for a kill switch as it will ground the -ve side of the coil.
