Found a spare wire https://www.ausmini.com/forums/viewtopic.php?f=2&t=32004 |
Author: | Rodney [ Tue May 22, 2007 5:56 pm ] |
Post subject: | Found a spare wire |
Had the dash off of Ribena lately and I've found a wire that seems to be 'spare'. It's white with a black trace - the end has an insulated connector. I've tried to find what it's for from a few wiring diagrams but no luck. Maybe a previous owner did something and removed the accessory before selling the car. Your thoughts?????? Hooroo |
Author: | miniron [ Tue May 22, 2007 6:17 pm ] |
![]() White with a Black trace is usually an ignition wire between the coil and distributor. Just a guess but could be a sensing wire for the later 3 instrument Clubman voltage sensing tacho???? RonR |
Author: | sports850 [ Tue May 22, 2007 6:19 pm ] |
Possibly a hidden kill switch ??? Check the wires to the coil and see what colour they are . |
Author: | Mick [ Tue May 22, 2007 6:28 pm ] |
White/black I think goes to the coil, so is probably a tach sense wire. It's perfect for a kill switch as it will ground the -ve side of the coil. |
