It is currently Sat Jul 26, 2025 12:00 am
 Post subject: RADIATOR CAP! What size?
PostPosted: Fri May 25, 2007 10:44 am
Was topping up and forgot to pt the cap back on, I know, stupid.
Need to get the right size from the mech, but he wants to know what size before getting it in.
It's a standard 76 clubbie, any clues?
Clocked a faster hill climb than a WRX in a 998cc clubman!
PostPosted: Fri May 25, 2007 11:50 am
As far as i Know there are only two diameters - you need the larger one
13psi
Most minis had a "long neck" as standard but many have been changed to the more common short neck over the years. If you're ordering by phone you'll need to measure from the top of the filler down to the lip the cap seals against inside the neck and get your mechanic to measure the cap.
PostPosted: Fri May 25, 2007 3:31 pm
Got it, thanks
PostPosted: Fri May 25, 2007 3:38 pm
It's not that simple-
there are 2 different lengths, the Oz radiators have a longer neck than the Pommy ones. :wink:
For Australian made CPC caps-
Oz (long) p/no is 517/13
Pommy (short) p/no is 508/13, fits the UK 2 core and 3 core.
:wink:
PostPosted: Fri May 25, 2007 3:42 pm
:wink:
Thats the rule of thumb... but... I sent a Mini K radiator away once to have a new core fitted and it came back all shiney and new looking - with a short neck filler :?
PostPosted: Fri May 25, 2007 3:46 pm
Well there's always the exception... :lol:
If you start blowing welch plugs or hoses out, you have the long where you need the short.
