RE13 cam
https://www.ausmini.com/forums/viewtopic.php?f=2&t=32124
Page 1 of 2
Author:  8a8y8 [ Sat May 26, 2007 11:27 am ]
Post subject:  RE13 cam
Just want to see if anyone has trouble in the morning with a cold start?
I just got my engine back with the re13 cam but i find that in the morning when the car is cold it seems to idle funny even with the chock out.
Also how long do you normally run your car for before you drive it?
Author:  drmini in aust [ Sat May 26, 2007 2:38 pm ]
Any real sports cam will idle a bit lumpier when cold, including the RE13- you should hear my 282... :lol:
Wind the idle speed up a bit. :wink:
Author:  d1_davey [ Sat May 26, 2007 4:52 pm ]
mine is lumpy as in the mornings just let it warm for a lil longer then go driving
it dies if you try to drive it lol
it will say no and cough and then die lol :P
Author:  drmini in aust [ Sat May 26, 2007 4:53 pm ]
PM sent. :wink:
Author:  Lillee [ Sat May 26, 2007 6:22 pm ]
Narp. Cold start problems are usually to do with worn/badly adjusted points dissies more than anything else. Also badly timed. Also crappy starter motors.
I can start mine cold, hot or wet, first time, every time.
Author:  Spaceboy [ Sat May 26, 2007 6:47 pm ]
no problems starting, and the idle is horrific hot or cold, especially so when cold.
Use the fast idle setting on the choke to stop it from stalling.,
and i drive away gently soon as i have oil pressure
how do you like the power delivery though? 8)
Author:  Gilly [ Sat May 26, 2007 7:05 pm ]
I like the power delivery of Drminis Re: 282 even better.
It would be my next choice :twisted:
Author:  gafmo [ Sat May 26, 2007 8:44 pm ]
I Hear Ya
Can't say we have a problem but Morris is tucted away inside every night
Author:  8a8y8 [ Sun May 27, 2007 1:26 am ]
i think mine the SU cause itook of the ramflow filter and the car felt better stright away
Mine currently a dibgle su and i got suggested a HIF44 Su any suggestions?
Author:  pristic [ Sun May 27, 2007 8:00 am ]
Ive got a hot 1132 with RE13
Mornings were crap... lumpy and spluttery as heck! Drove me mad... took about 10min of soft driving to warm up... idle wouldnt warm her up.
Mine has a HS6 and the issue was that it was sucking too much air through the little intake on the carby (where a hose goes normally)
Do you have a hose (tube) going from the engine breather (crankcase in my case) to the carby?
Also, mine sounds like its going to stall but doesnt... just really really sounds like it.
I use the choke to start it, run for about 30sec - 1min and then push it back in...
Peter.
Author:  tinymorris1969 [ Sun May 27, 2007 12:25 pm ]
my start ups now in cold season are harder but with the choke on she still starts and with the cam in it sounds as lumpy as all hell but stops when i push the choke in about half way and leave it till warmed up
Author:  Maxi23 [ Sun May 27, 2007 12:30 pm ]
Are you running an RE13 cam ?
Author:  tinymorris1969 [ Sun May 27, 2007 12:30 pm ]
yeah
Author:  Maxi23 [ Sun May 27, 2007 12:34 pm ]
Everyone has these cams nowadays :shock:
Author:  tinymorris1969 [ Sun May 27, 2007 12:35 pm ]
lol WE NEED MORE POWER THERE CAPTON
