It is currently Sun Jul 20, 2025 10:25 am
 Post subject: Brake pipe
PostPosted: Mon May 28, 2007 3:09 pm
Took the car for its first 30mph emergency stop test before I send it off for blue slip - soon I hope - just need seatbelts and a a washer bottle
Stomped the [edal and the brake pipe from the master to union seperated at the pipe connection. Not only did it fire brake fluid everywhere it left me with no brakes - :shock: :shock: The pipe came clean out if screwie end bit. - not going back to that pipe guy again.
I bit of handbraking, gear chnaging and going around in circles got me to stop.
So thats one more thing I have to add to the list.
Two steps forward etc
PostPosted: Mon May 28, 2007 3:23 pm
i know how you feel, i have done all my brake lines myself and we bled them on saturday wasnt a problem but when we checked for leaks found a connection in the pod was only finger tight and fluid everywhere
:cry:
PostPosted: Mon May 28, 2007 3:31 pm
Been there , done that but it was a corrosion problem , took the moke in for a rego check and the guy said "put your foot on the brake" to check the brake light's , "put your foot on again and hold it on" , "I can't , my foot sank almost to the floor" .... Pipe from the splitter block (whatever it's called) on the front subframe to where it joins the right front hose had let go with a rust hole :oops: :oops: , we looked at the pipe , then each other , then the pipe and both swore in unison .
PostPosted: Mon May 28, 2007 3:33 pm
ian i cant imagine a mod swearing are you telling the truth
:lol: :lol: :lol: :lol:
PostPosted: Mon May 28, 2007 3:34 pm
Have you considered going back to that guy who made the pipe armed with a club? He coulda killed you.
PostPosted: Mon May 28, 2007 3:40 pm
Of course , just like I imagine you to be a courteous and helpful driver like the other coke truck drivers :lol: :lol: :lol:
PostPosted: Mon May 28, 2007 3:43 pm
nar - wouldnt get no satisfaction
but that is why I test evrything in a safe place with plenty of runoff and things to passively stop me.
PostPosted: Mon May 28, 2007 3:52 pm
You did it facing your neighbours house :shock: :shock:
PostPosted: Mon May 28, 2007 3:55 pm
Nup - If I come up my one way street the wrong way @ 30mph, take my foot off the gas about 10metres before my garage and turn right with the handbrake it stops approx 30 cm from the end wall of my garage.
tested many times - once the dog was in the way :shock: so I had to use the foot brake
Tried it in the Jag once - didnt make it - went straight through the plasterboard wall into the garage bathroom :oops:
 Post subject: Garp
PostPosted: Mon May 28, 2007 8:58 pm
The World according to Bloke :roll:
Users browsing this forum: Bing [Bot] and 95 guests
