Luminition Magnetronic electronic ignition? https://www.ausmini.com/forums/viewtopic.php?f=2&t=32158 |
Author: | GT [ Sun May 27, 2007 5:02 pm ] |
Post subject: | Luminition Magnetronic electronic ignition? |
I was going through the shed today looking for stuff to get rid of. I found a 29D Clubman GT dizzy. Took the cap off and it has a Luminition Magnetronic module in it. I know nothing about this type of electronic ignition. Anyone know about this brand of electronic ignition? I googled this: http://www.ahspares.co.uk/products/LUMI ... LI199.aspx Looks like it doesn't need a module unit out of the dizzy. Is that right? |
Author: | drmini in aust [ Sun May 27, 2007 5:11 pm ] |
Anton, I've not used one but I believe they are self-contained, like the Pertronix Ignitor is. |
Author: | GT [ Sun May 27, 2007 6:49 pm ] |
Interesting..... Are they any good? I am thinking about giving it a whirl in my GT. |
Author: | Blokeinamoke [ Sun May 27, 2007 8:44 pm ] |
Yep they are good - set and forget like the others. Just makes sure you retime after you install as the the timing can change slightly. |
Author: | Blokeinamoke [ Sun May 27, 2007 8:49 pm ] |
I forgot about watching out for tacho bounce which is known especially with these units |
Author: | Boostedmini [ Sun May 27, 2007 9:34 pm ] |
Hi Anton, that is the version i was running before i fitted the megajolt unit, worked great for me mate, no issues in about 5 years of running Grant |
Author: | GT [ Sun May 27, 2007 9:52 pm ] |
Cheers guys. So this replaces the points and condensor? What coil do I use? The one that was with this dizzy is a BOSCH, and on the bottom it says GMH - Use With Resistor |
Author: | Boostedmini [ Mon May 28, 2007 7:46 am ] |
I was using a std bosch coil with no resistor. Grant |
