clutch drag problems! help me plz
https://www.ausmini.com/forums/viewtopic.php?f=2&t=32168
Page 1 of 2
Author:  >Rude< [ Sun May 27, 2007 6:21 pm ]
Post subject:  clutch drag problems! help me plz
Hey all,
A few of you may kno that i replaced my gearbox in the last few weeks and its all back in and have been driving it for a week now with a few lil problems that i hoped would go away. more to the point that the clutch is draging! im not a real expert at tinkering with clutch adjustments, would it jus need adjusting that it is doin this??
Hope someone can help me out cause its buggin me bigtime.
>Rude<
Author:  Timbo [ Sun May 27, 2007 9:51 pm ]
An adjustment might help, but a whole lot of things can cause clutch drag from oil thats too thick (that wynns stop-smoke is terrible for it) through to worn out clutch mechanism.
Start by pulling the arm out as far as you can by hand then screwing out the little 7/16 bolt until its head is just touching the arm then screw it back in one flat (i.e. one sixth of a full turn). Then get someone to push the clutch in and make sure that the big nut on the end of the clutch throwout arm isn't pressing up against the clutch cover, if it is, back it off until there's a gap. If the clutch clears properly now, its an adjustment problem. If it still drags you've got other problems.
Author:  graham in aus [ Mon May 28, 2007 10:35 am ]
These sort of problems are almost always due to wear in the clutch actuating mechanism, strip out the arm and check ball end and all the clevis pins for wear, a little wear on each adds up to exactly your problem!
Author:  >Rude< [ Mon May 28, 2007 11:12 am ]
thing is that it worked perfectly before i had these gearbox dramas and replaced the gearbox, ill try what you said timbo but it sounds a lil confusing to me pics would help lots :?
>Rude<
Author:  Timbo [ Mon May 28, 2007 1:39 pm ]
>Rude<
What manuals do you have? There are pictures and better descriptions in all the common ones.
Author:  peterw [ Mon May 28, 2007 3:09 pm ]
A common problem with mini clutches is that the actuating lever bends over time. They are normally slightly curved. Can't remember how many times I have had a clutch lever in the vise to bend the curve back in it (with a hammer of course). If it straightens out too much it can stop the clutch from completely disengaging because the slave cylinder reaches the end of it's travel before the clutch is completely disengaged.
Also, the adjustment of big nuts on the end of the throwout shaft is important. Any manual should explain this adjustment. If not adjusted properly the clutch machanism can float around when disengaged and puts excessive pressure on the throwout bearing accelerating the wear.
Worth checking these as well as the adjustment of the 1/4UNF bolt/locknut.
Pete
Author:  Mick [ Mon May 28, 2007 3:17 pm ]
bolt/locknut.
Pete
They actually were straight from the factory, the curve is put in by owners to make up for the worn components like the ball and socket and clevis pin. It gives the unit a little extra throw.
Author:  >Rude< [ Mon May 28, 2007 5:47 pm ]
here is a pic i just took....
>Rude<
Author:  64cooper [ Mon May 28, 2007 9:34 pm ]
Rodney
your pic will not show any obvious problems. If you had the return spring removed and the lever operated by hand to check the gap between the operating lever and the bolt on the housing, we may get a more clearer picture of your problem if it is at that point. As others have pointed out previously, there are a number of factors that come into play when clutch problems like yours arise. As in PM, the offer still stands, come on over or vice versa, and we can go over every thing to ensure you get back to the enjoyable experience of driving a Mini.
Author:  peterw [ Mon May 28, 2007 11:55 pm ]
I stand corrected on the curved clutch arm. The 8 minis I have owned all had curved levers so over bending them must be a common practice.
I did notice one thing in your photo worth mentioning. There seems to be a bracket missing from your engine steady. There is normally an S shaped bracket that goes from the outer side of the rubber bush to the hole in the block approx 5 cm forward of it. Without this the bolt might work in the hole and eventually break. If yours is a very late model it may not have had this bracket but I have never seen a Mini without one.
Hope you get your clutch fixed soon.
Pete
Author:  TheMiniMan [ Tue May 29, 2007 12:02 am ]
Sounds to me that you more than likely have a problem with the idler gear &/or primary gear having not been "End Floated"correctly
that is to say that """IF""" the end float clearance of one or both of those gears is set too tight, then it will feel like the clutch is dragging
who set the end float on both those gears whilst/when re-fitting the gear box job????
Author:  Moke'n'Andy [ Tue May 29, 2007 5:27 am ]
my clutch was slow to release and was slipping - it turned out to the the small hose from the master to the slave cylinder was not letting the fluid back fast enough.
Not sure if this is the same as your problem, but once replaced it was as good as gold.
Author:  >Rude< [ Tue May 29, 2007 10:28 am ]
do you or anyone else have a picture of this??
that makes no sense to me at all, sorry matt, im not all there with gearbox related things :? :? my mechanic who did the majority of the work rebuilding it with me the first time did put it all back together again (also helped in pulling it apart) but he is no mini expert but worked fine the first time we did it....
Author:  64cooper [ Tue May 29, 2007 7:40 pm ]
Nice pickup in the photo peterw, the bracket he needs is made up of items 10 and 16 in pic (below).
Rodney, we all probably have these lying around so I will dig some out for you.
Author:  TimB [ Tue May 29, 2007 9:38 pm ]
My mini sits in the driveway suffering the same thing. I've replaced everything except the slave cylinder, which I will do when motivation kicks in next.
