It is currently Fri Aug 08, 2025 12:31 am
 Post subject: A+ compression
PostPosted: Sun May 27, 2007 6:50 pm
what sort of compression figures should I expect from a 1275 A+
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
 Post subject: Compression
PostPosted: Sun May 27, 2007 7:30 pm
Compression always depends on what piston dish size, gasket thickness volume, and head chamber capacity. measure the swept volume add to the total of the three above capacities and again devide that total by the total of the three capacities being head chamber, gasket and piston dish.
Swept volume = Bore radius times 22, devide by 7, multiply by stroke length.
Always easier to work this in Millimeters.
One will be surprised how many engine builders don't have a clue how to work this and they bore blocks out and machine heads down and bolt them together without even thinking that the compression can go through the roof.
"Let us remove your "SHORTS"
PostPosted: Sun May 27, 2007 8:12 pm
mine was second hand, un reco'd etc. compression was 175,180,180,175.
PostPosted: Mon May 28, 2007 7:30 am
thanks guys
'71 Wolseley 1300
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
