It is currently Sat Jul 19, 2025 1:10 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
 Post subject: Rollmaster Timing Chain
PostPosted: Mon May 28, 2007 11:41 am
Anyone know who stocks these?
I believe the Rollmaster is a vernier adjustable kit, with an Iwis chain, which is meant to be the better chain??
Any help appreciated.
Thanks
PostPosted: Mon May 28, 2007 11:49 am
I got mine from victorian performance warehouse website,
Cheap and quick delivery too!
A note, make sure you time the cam in with a cam timing gauge etc, don't just rely on the marks on the gears!
PostPosted: Mon May 28, 2007 11:53 am
That will be Graham Russell's job :wink:
Cheers for the heads up, I'll have a look now
PostPosted: Mon May 28, 2007 12:03 pm
I see no Mini parts in this list...
http://www.vpw.com.au/productgroup.asp? ... GrpID=3620
You got a part number or anything Matt?
PostPosted: Mon May 28, 2007 12:33 pm
why don't you go for a belt?
PostPosted: Mon May 28, 2007 12:44 pm
Not necessary
PostPosted: Mon May 28, 2007 12:47 pm
I lol'd, william....
PostPosted: Mon May 28, 2007 12:51 pm
Im using a dual row timing chain which i think is rollmaster. It was also meant to be vernier adjustable. But the adjustability of it is limited, as it just has 4 (i think) keyway grooves on the crank sprocket (i think).
Its not like those flash ones that ive seen with allen head screws on the inner part of the sprocket to allow for more adjustability.
But on the invoice, it clearly states Vernier Adjustable Dual Row Timing Chain.
I dunno....?
PostPosted: Mon May 28, 2007 12:55 pm
but do you know if it actually works?
i suppose the only way you could see it turn was if you had it in gear, when you were pushing the car up onto the trailer.
:P
PostPosted: Mon May 28, 2007 12:56 pm
Why did i even bother posting a comment.
vernier adjustable just means that the offsets are slightly different for each hole, and when you mate different holes with the crank hole, a slightly differnt alignment is the result. have a look at a real set of vernier calipers and you will see what i mean.
if it had the allen bolts in slots, then that would be infinitely adjustable tooth to tooth, because you can offset the alignment by any amount you choose. it is not restricted by fixed offets.
michae
PostPosted: Mon May 28, 2007 12:58 pm
Yep, thats the style that i have. Just the grooves.
PostPosted: Mon May 28, 2007 12:59 pm
All good comments (except for Cush's) but does anyone know where I can get the Rollmaster chain kit?
Karcraft don't sell it.
VPW doesn't sell it (doesn't look like it anyway).
PostPosted: Mon May 28, 2007 1:00 pm
Im pretty dam sure that i would have sourced mine from Mini Kingdom, now Mini Spares.
PostPosted: Mon May 28, 2007 1:08 pm
how about here, will?
http://www.romac.com.au/
