It is currently Sat Jul 19, 2025 2:22 pm
 Post subject: Fuel tank
PostPosted: Wed May 30, 2007 1:50 am
hey all, removed the fuel tank to put in some new rear shockies "GAS ADJUST" while the tank is out i thought of checking for leaks as i have noticed a fuel smell in my boot .. the breather wasn't directed out of the car probably the go but is there a easy way to check for leaks... i have the tank exterior pretty clean and have been sloshing a small amount of fuel around in the tank to see of any seaps out so i can locate.... cheers any suggestions
PostPosted: Wed May 30, 2007 5:04 am
Compressed air in - soapy water on the joints. You'll soon see if there are any leaks :D
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Wed May 30, 2007 6:40 am
If it has a leak, the tank will be damp with fuel under the bottom, where they rust out.
Putting any more than a couple of psi air pressure in there is dangerous. The tank ain't built like an air receiver, so beware... :wink:
