Fuel tank https://www.ausmini.com/forums/viewtopic.php?f=2&t=32271 |
Author: | Fiji [ Wed May 30, 2007 1:50 am ] |
Post subject: | Fuel tank |
hey all, removed the fuel tank to put in some new rear shockies "GAS ADJUST" while the tank is out i thought of checking for leaks as i have noticed a fuel smell in my boot .. the breather wasn't directed out of the car probably the go but is there a easy way to check for leaks... i have the tank exterior pretty clean and have been sloshing a small amount of fuel around in the tank to see of any seaps out so i can locate.... cheers any suggestions |
Author: | ClubmanGT [ Wed May 30, 2007 5:04 am ] |
Compressed air in - soapy water on the joints. You'll soon see if there are any leaks ![]() |
Author: | drmini in aust [ Wed May 30, 2007 6:40 am ] |
ClubmanGT wrote: Compressed air in - soapy water on the joints. You'll soon see if there are any leaks
![]() If it has a leak, the tank will be damp with fuel under the bottom, where they rust out. Putting any more than a couple of psi air pressure in there is dangerous. The tank ain't built like an air receiver, so beware... ![]() |
