Brake Master Cylinder Mods https://www.ausmini.com/forums/viewtopic.php?f=2&t=32301 |
Author: | Vtek16 [ Wed May 30, 2007 11:58 pm ] |
Post subject: | Brake Master Cylinder Mods |
Hey Guys, Ive run into a little bit of a problem with clearance issues between my late model Twin servo master cylinder and the Dizzy Cap, (B16A2) at the moment there is just not enough room where i need it with the current steel lines.. iv looked into braided lines and will change over to them as part the next thing i do (The rest of the brake system is braided) but the banjos that are on the market are huge and just aint gunna fit ( iv even tried Modified Banjo's) iv looked into fabricating a plate on a angle to bolt between the servo & master cylinder to provide extra clearance but this comes with its own issues such as the pin would strike on a angle What i would ideally like is a Master cylinder exactly the same specs but with the outlets on the opposite side ......If anyone has heard of such a thing could you please let me know, or if you have any other ideas or comments id love to hear from you Thx Ash |
Author: | minimetoy [ Thu May 31, 2007 10:08 am ] |
If you search back through 13 sec's build you should find a photo of his master being turned about 70 degrees. He had the lugs cut of the master and welded in a different location. Dan |
