It is currently Sat Jul 26, 2025 10:56 pm
 Post subject: hydro
PostPosted: Wed May 30, 2007 8:39 pm
g'day i went to connect my hydros up and the end of the hydro pipes dont connect up to the end of the bags is there a connection that i need for the to join????
PostPosted: Wed May 30, 2007 8:53 pm
Sure is. You need the threaded male connectors LH & RH for the front ones Part# 21A1524 & AYA4052
PostPosted: Wed May 30, 2007 8:54 pm
The flexible hoses on the rear go to the center back of the subframe where there will be unions to join to the steel lines up the middle of the car.
Same for the front except they are either side of the carb standing vertically.
Other than that you will need to provide a LITTLE more information.
PostPosted: Thu May 31, 2007 7:54 am
oh ok how much are those connectors worth for the engine bay2?
